05-17-2008, 09:34 PM
Start at the center bolt, just below the rocker cover.
Jump to the next closest bolt in a counter clockwise circle moving out till all bolts are tight.
Four steps to torque bolts, 40, 70, 80 and 80 foot pounds are the torque values.
As long as the universal is close to straight, it should not change the value enough to worry about.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
www.ford-trucks.com/guidelines.html
FTE Moderator in the IDI diesel forum.
WV Chapter Member
