Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Expedition & Navigator 1997 - 2002 and 2003 - 2006 models
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 10:22 AM
rews2 is starting off with a positive reputation.
AC Recharge
Is there a bonehead way to tell if my AC needs a freon charge?
It seemed to not be as cold towards the end of last summer and now at times I get nothing but warm air blowing out. Last night I tried it and it worked fine but that was 7:00pm when it was 80 not noon when it was 90. Also when I turn the AC on I hear a noise from the rear inside drivers side like something trying to cycle on and off but it never cycles off.
I read in a thread before about a blender door being stuck open or something like that?
As always thanks for the input.
__________________
2003 Expedition XLT
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-18-2008, 12:12 AM
I picked up one of those idiot type of guages that shows the system having a charge in the correct zone. I had her running for about 20 minutes at idle with the back top panel off and the noise is more of a hissing sound. Also I noticed that the clutch engaged when the unit is turned but it never cycled on and off, does anyone know if these have a cycle switch and if so where it is.
__________________
2003 Expedition XLT
  #3 (permalink)
Old 05-18-2008, 05:42 AM
Freak4Ford's Avatar
Freak4Ford is starting off with a positive reputation.
If your system is properly charged then your compressor should continously run as long as its calling for cooling. The hissing noise your hearing is more than likely the refrigerant as it works it way through the rear evaporator. There should be a cut out switch for when the engine is under heavy acceleration. But there is no cycle switch. If the unit is cycling either its low on refrigerant or it has met the demand of the system.
__________________
2004 Navigator Ultimate 4wd
Superchips Tuner
Aero Exhaust S/S Muffler
MagnaFlow S/S Resonator
22" wheels
305/40 tires
  #4 (permalink)
Old 05-18-2008, 06:29 AM
projectSHO89 is gaining momentum as a positive member of FTE.projectSHO89 is gaining momentum as a positive member of FTE.
Of course there's a cycling switch. All fords have them. It's mounted on the accumulator and there's probably nothing wrong with his.
The OP needs to investigate his clutch air gap.
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #5 (permalink)
Old 05-18-2008, 10:14 AM
How would I check clutch air gap? Is this something I can do or do I need to take it to an A/C shop?
It's already hitting triple digits here during the day so I want to move on it as quick as possible I don't want my girls riding around in a truck blowing warm air.
__________________
2003 Expedition XLT
  #6 (permalink)
Old 05-18-2008, 11:16 AM
sbclemens is starting off with a positive reputation.
It sounds like its low on refrigerant. I live in Phoenix and I'm driving a 98 with the original charge. You may want to take it in to a shop so your system can be leak tested.
__________________
98 Expy XLT 4x4 5.4L
  #7 (permalink)
Old 05-18-2008, 11:59 AM
There are over 170 threads on this site that come up when you plug "+clutch +air +gap" into the SEARCH tool.
Refrigerant level can be checked with a gauge. At 80F, the static charge in the system will be enough to register around 85+ psi in the system with the engine off an cold.
Dang it, where's that HVAC FAQ???
Steve
__________________
  #8 (permalink)
Old 05-18-2008, 12:12 PM
proshadetree is starting off with a positive reputation.
Should be about 30 to 35 psi running on low side>If it drops into the teens it will start to cycle on and off.
  #9 (permalink)
Old 05-18-2008, 08:56 PM
I checked and with ac on max and at idle it was a solid 35 psi. I reved it up some but was under the hood so not sure how high the rpm's were and it dropped to right around 18 psi.
I did search the clutch air gap and found some good info. The one constant on those threads seemed to be that the clutch would spin and then stop causing some to tap it with a screwdriver etc but mine doesn't stop spinning until I shut it off. I pulled the clutch face and tried it with no shim as some threads suggested but then the clutch stays engaged even when I turned it off. I found a thinner guage shim/washer and put that in but still no dice. I can say that it "seems" cooloer at first so maybe even a thinner guage shim? The one I tried is around .021 according to my feeler guage.
__________________
2003 Expedition XLT
  #10 (permalink)
Old 05-18-2008, 09:06 PM
Unfortunately, having only the low side pressure is like trying to drive with only one eye...you only get half of the needed information and still can't tell if the charge is correct.
However, at least you know the clutch is engaging.
MEASURE the air gap. See if it is in spec, then perform the shim removal ONLY if indicated.
Steve
__________________
  #11 (permalink)
Old 05-18-2008, 10:10 PM
I get what you're saying about needing to have the high side checked also.
This reminds me alot of my F250 when the cycling switch went out. Crap I hate a/c stuff!
__________________
2003 Expedition XLT
  #12 (permalink)
Old 05-19-2008, 10:12 PM
ac did work better this morning leaving the house with an outside temp of 88 at 7:00 am but coming home at 6:00 pm outide temp was 106 and it didn't work as good. At least the air blowing wasn't as hot as before and actually felt cool at times.
So I'm going to have the high side psi checked as suggested and also try to track down a smaller guage shim, I think I saw one thread that had specs at .014-.030 does that sound about right? Also is there an actual shim kit for this or do you just find a thinner washer/shim?
__________________
2003 Expedition XLT
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
