Gear Shift locked - Ford Truck Enthusiasts Forums
Gear Shift locked
Old 05-17-2008, 08:22 AM
daypray1 daypray1 is offline
daypray1 is starting off with a positive reputation.
Gear Shift locked
When trying to put my 200 F-150 truck in gear, my gear shift is locked. I have to pump my breaks a few times to get it to go in gear. Any idea what the problem may be?
Old 05-17-2008, 09:31 AM
FatalErrorz FatalErrorz is offline
FatalErrorz is starting off with a positive reputation.
I'd have to see it....Try to bypass the interlock switch, or maybe you have a vacuum leak, or maybe Ford has gotten creative to the point of locking out the truck when your brakes wear to a certain point and the fluid gets low.
Old 05-17-2008, 10:44 PM
Thanks, i am in need of some new brakes, so that may be it.
Old 05-18-2008, 07:02 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Quote:
You're kidding...
Brake light switch or the wiring to it is staring to get intermittent.
Your owner's manual has the procedure for emergency bypassing of the shift interlock.
Steve
Old 05-18-2008, 09:38 AM
Quote:
Originally Posted by projectSHO89 View Post
You're kidding...
Steve
My sister's Lexus won't come out of Park if her brake fluid's low, as in, if she ignores her brakes, when the fluid gets down to a caertain level, it don't move no more. It's a safety thing. It has a bunch of criteria that will either keep it from starting, or going into gear.
Old 05-18-2008, 10:52 AM
wildcard30's Avatar
wildcard30 wildcard30 is offline
wildcard30 is gaining momentum as a positive member of FTE.
Hey... I thought this was the F-150 Forum! Makes me glad I don't own a Lexus. You may want to verify your info to make sure it applies to Ford products before you post it...
Here's how to bypass the interlock. This is from the owners manual.
Brake-shift interlock - column-shift transmission
This vehicle is equipped with a park/brake-shift interlock feature that
prevents the gearshift lever from being moved from P (Park) when the
ignition is in the ON position unless the brake pedal is depressed.
If you cannot move the gearshift lever out of P (Park) with ignition in
the ON position and the brake pedal depressed, it is possible that a fuse
has blown or the vehicle’s brakelamps are not operating properly. Refer
to Fuses and relays in the Roadside Emergencies chapter.
If the fuse is not blown, perform the following procedure:
1. Apply the parking brake, turn the ignition to OFF/LOCK, then remove
the key.
2. Locate the round access plug on the underside of the steering column cover.
3. Remove the access plug using a flat head screwdriver, then push the
override button using a flat head screwdriver, apply the brake pedal and
shift the transmission into N (Neutral).
4. Reinstall the access plug cover, start the vehicle and release the
parking brake.
Brake-shift interlock - floor-shift transmission
This vehicle is equipped with a brake-shift interlock feature that prevents
the gearshift lever from being moved from P (Park) when the ignition is
1. Apply the parking brake, turn the ignition to LOCK, then remove the key.
2. Open the center console bin. Using a screwdriver, carefully pry off the console finish panel surrounding the shifter mechanism by inserting a
screwdriver into the latch slot as shown.
3. Remove console finish panel assembly to expose the inside of the gearshift.
4. Press and hold the white button located along side the shifter
housing assembly (as shown in the illustration). Press the gearshift lever release on the shifter **** and move the gearshift lever back to N (Neutral) (two places rearward from P [Park]).
5. Start the vehicle and release the parking brake.
Old 05-18-2008, 12:31 PM
the key.
parking brake.
Actually, you may want to read and COMPREHEND what I wrote before attempting to rebut me. I advised the guy of the option to bypass the interlock switch, and said that perhaps Ford had gotten creative to the point of the brake fluid working in conjunction with the interlock. At no time did I say that was the problem. Can you troubleshoot his problem via a keyboard and monitor? NO! Anybody, including me (which I did) can tell someone to bypass their interlock, but WHY is his interlock locking him out in the first place? He already said his brakes are shot. I mentioned the Lexus as an EXAMPLE, just like many on here mention Toyota, Dodge, and Chevrolet, including cars. Don't like it? Don't read my posts.
Old 05-20-2008, 05:51 PM
wildcard30's Avatar
Why all the angst and histrionics? Relax.... You take yourself way to serious....
Gear indicator on LCD tracyclifton 6.7L Power Stroke Diesel 6 08-10-2015 11:16 PM
Engine stalls when shifting into gear rogerhinson 1978 - 1996 Big Bronco 2 03-20-2011 01:22 PM
Torque Converter Lock up al4d davidisit Bronco II 3 03-13-2011 11:51 PM
92 Ranger Manual Transmission Problem fiddy dollars Ranger & B-Series 5 11-28-2010 09:59 AM
SCT Lock 1-2-3 jlo84truck 6.0L Power Stroke Diesel 4 04-07-2010 11:54 PM
Tags
2004, access, button, cover, f150, ford, gear, locate, locked, onthe, plug, round, shift, steeringcolumn, underside
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
