Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1997 - 2003 F150 97-03 F-150, 97-99 F250LD, 7700 & 04 F-150 Heritage
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 07:29 AM
doc980277 is starting off with a positive reputation.
Fail Safe Cooling on, but not hot
Hey this is my first post so a little paitence will be neccessary, and thanks in advance!
i have 1997 f150,2wdr,ext cab,4.6engine, lariat..150000mies
Normal driving, temp gauge all at once pegs to maximum temp, oil light comes on, check engine light on, fail-safe cooling comes on. I can put in neutral and switch off then restart , while rolling and all goes back to normal. sometimes it takes a few times to do this and then its good for the rest of the day. Engine is not hot at all. this is my work truck and when others have had it in the shop over the last 6 months, replace water pump, radiator, therostat, uper rad. hose and i think its all for nothing.
Any help would be great...thanks again....Doc
  #2 (permalink)
Old 05-17-2008, 08:56 AM
galaxie641 is starting off with a positive reputation.
I wonder if there is an air bubble in the cooling system that tricks the temp sensor when it gets around it.
__________________
'48 F1 Flat6
'51 F3 Flat8
'64 Galaxie 352 4bbl
'68 F150 390
'72 F250 400/C6
'97 F150 5.4L
  #3 (permalink)
Old 05-17-2008, 12:23 PM
will simply burbing the system mend that?
  #4 (permalink)
Old 05-17-2008, 04:08 PM
442w30 is starting off with a positive reputation.
My 05 5.4 with 90,000 was starting to show a similar symptom. It would not peg the gauges it would just go into failsafe. I would usually be able to clear by just turning engine off then restarting. But of late it started taking longer to clear, the last episode was when I was in the desert camping. I had to disconnect battery and let it sit overnite before it would clear, drove straight to the dealer, of course they could not duplicate and since I had disconnected the battery no codes. GOOD LUCK!
  #5 (permalink)
Old 05-17-2008, 06:05 PM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
No, it reads actual head temp, not coolant. Sounds like you may have a bad temp sensor.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #6 (permalink)
Old 05-18-2008, 05:25 AM
Joe Finn's Avatar
Joe Finn is starting off with a positive reputation.
Quote:
As LxMan1 said, sounds like the temp sensor. Actual temps don't change that rapidly.
__________________
'97 F150 4x4 XLT 4.6L 3.55 LS Supercab
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
