Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 07:16 AM
2 stroke man is starting off with a positive reputation.
boost woes
i need some help guys. i mentioned awhile back about my turbo not boosting much lately. my EGTS are staying high, and my boost will barely hit 20 poundsfor a brief time with a moderate load, in drive, to the floor on a hill at 70 mph with 3,000 rpms. cruising with a load, i'm lucky to make 5#. any ideas? hopefully the turbos going bad, to make way for a new one =). but, no shaft play, and my compressor wheel is nice and smooth. with just 6,700 pound trailer cruising along my egts are hittin 850* in od.
__________________
"i'm like a shopaholic on cocaine.....except not on cocaine"
-the GF
97 Stroker. not enough mods. only Superchip, K+N, DP, Tranny, Trans Cooler, Rims, hood, all the other nice accessories. FOR SALE
  #2 (permalink)
Old 05-17-2008, 07:36 AM
c00nhunterjoe's Avatar
c00nhunterjoe has a good reputation on FTE.c00nhunterjoe has a good reputation on FTE.
20 psi is really good for your mods, its all i can do to touch 20 psi for a split second and i have to hold mine in gear to almost 3400 to even try.
- wot in mine at 3000 rpm is roughly 15-18 psi
-towing a load in od means low rpm's. 7k at low rpm and only hitting 850 is really good as far as i'm concerned.
- cruising with or without a load i make basicly no boost, the gauge wont climb till i am on the throttle down geared.
- only time i get boost on a cruise is 70-80 mph on light hills, i can build 5-10 psi but the rpm is up between 2000(70) and 2500(80) at that point.
- 55mph is 1500 in my truck, that = 0 boost for me.
__________________
97 F-250, 4.10's Auto, Superchip, All mods by c00nhunterjoe's performance shop http://community.webshots.com/user/c00nhunterjoe
http://youtube.com/c00nhunterjoe
  #3 (permalink)
Old 05-17-2008, 07:37 AM
just noticed teh signature----- leaky up-pipes cause low boost and higher egt's but your numbers dont really sound bad
__________________
  #4 (permalink)
Old 05-17-2008, 08:41 AM
MADVAN is gaining momentum as a positive member of FTE.
Agree on the leaky pipe thing.
On another note check your idle and wot fuel pressure.
I remember you having an issue with FPR.
Bill
__________________
97 4X4 PSD Quigley
Supporter/End user of ShiftSolutions The CURE E4/4R Trans Control. Helping Cancer patients and families. www.fordtransmissioncure.com Video of No OD Bump/Slip Shiftpoint
Special thanks to RacerX www.racerxautomotive.com
  #5 (permalink)
Old 05-17-2008, 09:53 PM
i checked pipes the other day. they were tight. i unplugged my MAP today, it seemed to run better unplugged
__________________
-the GF
  #6 (permalink)
Old 05-17-2008, 10:14 PM
foxracing0934's Avatar
foxracing0934 is starting off with a positive reputation.
I dont know, i have a similar set-up to you and i can get between 25-28 psi. I wonder if it could be a leaky up pipe? Less exhaust gasses meaning less spool up.
__________________
97 F-350 w/74,*** miles
DP Tuner F5 chip (40,80,100,120)
S.S. HPX Line
3in down pipe
4in MBRP w/o cat
65 psi FPR
Dipricol Gauges (Tranny, EGT, Boost)
Soon to Come:
DIY Sage 1's or 2's(???)
6.0 Spearco Intercooler
H2E Turbo
6637 Intake
Mickey Thompson MTZ's
  #7 (permalink)
Old 05-17-2008, 10:18 PM
Robbgt's Avatar
Robbgt is gaining momentum as a positive member of FTE.
Quote:
With stock injectors?? what setting is you DP on??? That some boost from stock sticks! Like c00n said, most are happy with 20ish from stock sticks...
-Robb
__________________
97 F-350 XLT 4x4 PSD, E40D, 3.55's, 153K, 6637, 140V IDM, HPX, FPR Shim, Hotfoot, Tymar DP, Dual Exhaust, T/C Lockup mod, new GP's, Stancor GPR.
>>FOR SALE: FTE Classifieds<<
  #8 (permalink)
Old 05-17-2008, 10:52 PM
ya i have stock injectors, 4.10's, and in the 80 horse setting i can get like 26 psi, on the 120 setting i can get like 27-28 psi. And i'm soon getting stage 2 DIY's!!
__________________
S.S. HPX Line
3in down pipe
4in MBRP w/o cat
65 psi FPR
Soon to Come:
H2E Turbo
6637 Intake
  #9 (permalink)
Old 05-17-2008, 10:54 PM
Robbgt's Avatar
Wow good stuff man! careful with those 2's.... start creeping up on 35PSI IIRC and the stock turbo is toast... you can talk to TJ about that...
-Robb
__________________
  #10 (permalink)
Old 05-17-2008, 11:00 PM
Y i read on here somewhere that you can run 35psi but only short bursts. Its ok i plan on an H2E and a Spearco 6.0 intercooler from black widow. My only fear is that i will soon be into head stud range..... and i dont want to do those.
__________________
S.S. HPX Line
3in down pipe
4in MBRP w/o cat
65 psi FPR
Soon to Come:
H2E Turbo
6637 Intake
  #11 (permalink)
Old 05-18-2008, 08:55 AM
is your truck a cali emmisions unit? 30 psi and 120 dp settings with no cel is odd for a 49 state truck
__________________
  #12 (permalink)
Old 05-18-2008, 05:47 PM
I dont know if it is or not, it could be because i needed to get a new part for it that was only on the cali truck but Rob posted a picture for me that was describing a cali truck and my truck didnt have that part on it. (A diaphram off the fuel pump maybe???)
__________________
S.S. HPX Line
3in down pipe
4in MBRP w/o cat
65 psi FPR
Soon to Come:
H2E Turbo
6637 Intake
  #13 (permalink)
Old 05-18-2008, 09:37 PM
Todd525's Avatar
Todd525 is starting off with a positive reputation.
Everyones gagues read a little differently, if he is hitting a TRUE 25 plus, he has one of the BEST running OBS in the country on stock sticks, we all know that.
2 stroke,
Honestly, empty on flat ground, stock sticks with ANY programmer you should see 1 to three pounds of boost, and EGTs should be 600to 650. Now this is with a GOOD set of gauges, and the sending unit IN the manifold, NOT in the pipe itself. That will throw you WAYY off. If your sending unit is in the drivers manifold, right at the rear of it where the flat spot is, then you are running REALLY well as coon said. Honestly with that weight in OD you should see about 1000 to 1050 if you have a 4.10 auto truck. If your seeing those numbers ( your 850 ) and you have the sender in the correct location, I would start looking for a new gauge.
__________________
96 F350 CC Dually PSD. Tuner, straight pipe, 6637 filter, ribbed diff cover, 12.7k mod, 28k tranny cooler, 3 plate TC, autometer boost, trans, and pyro. Used 4 Car Haulers, 5th wheels, goosenecks, Fat Chicks.
01 F250 CC 4x4 PSD. SOLD.....Kinda missed already, and its Day 1.
  #14 (permalink)
Old 05-19-2008, 08:55 AM
Neal 97 250's Avatar
Neal 97 250 is gaining momentum as a positive member of FTE.Neal 97 250 is gaining momentum as a positive member of FTE.
I used to be able to touch on the 25 psi boost with my stock sticks. Had to run it pretty hard to do it though. 22-23 was pretty easy.
__________________
97 F250 7.3PSD
X-Cab, SWB, 4X4
5spd, 4.10gears
3.5” DP, 4” Exh.
AFE Intake
FPR,BDP 140v IDM,CCV,HPX
Rosewood Stage II's
6 pos. TW chip, wow !!
'00 Excursion 7.3PSD 4X4
6637 intake
drill/slot rotors
Neal's Pics
  #15 (permalink)
Old 05-19-2008, 09:18 AM
tjbeggs's Avatar
Fisher of Men
tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.
My 95 which was pretty much stock with TEE5 programming (stock) hit 20 psi empty. I was amazed when I measured it. So I took my tymar, fuel pressure shim, and 10K mod off and still hit 20 psi. its possible.
__________________
Tim
Proud User of "The Cure"
For sale- 95 accelerator pedal, Gray interior and dash part, cab and more PM your request!
Click the Picture for wiring diagrams, tech info and Pictures!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
