Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 05:30 AM
BensDaddy's Avatar
BensDaddy is starting off with a positive reputation.
Talking 351m
Silly Question: Is the 351M considered a Small or a Big Block?
__________________
The more I get to Know women, The more I like My Truck
If you ever reach total enlightenment while drinking beer, I bet you could shoot beer out of your nose. -Jack Handy
  #2 (permalink)
Old 05-17-2008, 08:22 AM
BaronVonAutomatc is starting off with a positive reputation.
It's considered the b@st@rd of the 335/Cleveland series. Big block bell housing bolt pattern, uses 2v Cleveland heads, the 400 crank but with longer rods (IIRC) to shorten the stroke.
__________________
1986 Bronco w/300 I6 & ZF 5-Speed
1982 F250 4x4 w/302 & C6
  #3 (permalink)
Old 05-17-2008, 03:13 PM
Beanscoot is starting off with a positive reputation.
The 351M actually doesn't use the 400 crank. A 400 crank is used in the 400 engine and has a 4" stroke. The 351M engine uses a 400 engine block with a 3-1/2" stroke crank.
  #4 (permalink)
Old 05-17-2008, 04:59 PM
BensDaddy's Avatar
But does that make it a big block or a small block, there's five bucks riding on this
__________________
  #5 (permalink)
Old 05-17-2008, 05:06 PM
hunterkane's Avatar
hunterkane is starting off with a positive reputation.
351m is a big block
  #6 (permalink)
Old 05-17-2008, 09:48 PM
littleme13's Avatar
littleme13 has a good reputation on FTE.littleme13 has a good reputation on FTE.
its neither there isnt a small block or big block like with chevy. thats why we have so many engine forums on this site.
__________________
STGs Minions -BLING investigator
Tony
Quote:
Originally Posted by dragogt
Na, just rip off the finder's and take a bfh to the firewall, she'll fit like a glove.
MORE
Military Online RElay
military photo contest
  #7 (permalink)
Old 05-18-2008, 01:22 AM
Mejum size block
It's kind of a big small block. As mentioned, Ford considers it part of the "335" series engines. However, if you take a 351M head and place it on a 351W block, it will fit and the head bolts can be installed. So that means that important design features like bore spacing, head bolt pattern etc. were copied from the "small block" series.
  #8 (permalink)
Old 05-18-2008, 04:04 AM
johnboy427's Avatar
johnboy427 is starting off with a positive reputation.
I say all 335 series motors are small blocks, the 351C uses same mounts and tranny as a 302 and the other two are just alterations of that original small block. Heck like beanscoot said you can bolt the head on a 351W or a 302 that makes it all small to me. Surely a Big block should have a bigger bore than a 289 right? Well except some FEs I think.
-Johnboy
__________________
-1979 F-250 4X4 400 4spd
-1989 Bronco 300six swapped in ZF 5spd
-1967 Mercury Comet Sports Coupe
  #9 (permalink)
Old 05-18-2008, 08:10 AM
havi's Avatar
I'll have the roast duck
havi is gaining momentum as a positive member of FTE.
right....the 351M/400 bolts into the same frame perches as a 302/351W. Can't do that with a 429/460, or FE. Some of the first 400's had small block bolt patterns as well. The 351M came about 4 years after the 400 as a destroked 400. Crank and pistons are all that's different. Even the connecting rods are the same.
  #10 (permalink)
Old 05-19-2008, 06:45 PM
Big block bell housing bolt pattern, heads will fit on a small block. Sounds like a b@st@rd to me...
Use the five bucks to share a milkshake.
__________________
  #11 (permalink)
Old 05-19-2008, 07:35 PM
80broncoman is starting off with a positive reputation.
Quote:
Which part are you talking about? The rings also fit 289s,302s, all 351s and 400s.
The rocker arms and distubtor fit 351C, 400, 370, 429, and 460s
Valve covers, timing chain cover, timing gear parts, fuel pump, oil pans, and oil pump fits the 351C.
clear as mud, huh?
__________________
Real men don't wear Bowties
  #12 (permalink)
Old 05-20-2008, 12:52 AM
Rings
The rings also fit 350 Chev and some Dodge engines.
  #13 (permalink)
Old 05-24-2008, 08:50 AM
quesey's Avatar
quesey is starting off with a positive reputation.
Quote:
not to start anything here but you can bolt a 460 into 302 frame perches done it on over 10 trucks by useing fe motor mounts or now you can buy mounts from places like L&L.
__________________
1981 f-150 soon to be a 350 dually
1965 mustang fastback roller 302 dual 4's 5 speed
1968 f-100 460 c6
1986 mustang 351w
1978 fairmont 460 c6
1984 ltd wagon 9.23@148 mph 490 c6
  #14 (permalink)
Old 05-24-2008, 08:51 AM
havi's Avatar
Yes I know, but still not a direct bolt in.
Let me re-phrase that...bolt in without any creative mods or aftermarket parts.
Quesey: may I pick yer brain on your 351W into '86 Mustang?
  #15 (permalink)
Old 05-24-2008, 08:56 AM
BensDaddy's Avatar
As per the siggy. I'm from Halifax Nova Scotia Canada, havi, gas there just hit $1.339 per LITRE!!!! That works out to $5.208 per GALLON!!!! I'll pay the $4.00 per gallon and not complain TOO much!!!
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
