Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1997 - 2003 F150 97-03 F-150, 97-99 F250LD, 7700 & 04 F-150 Heritage
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 05:08 AM
crossf-150 is starting off with a positive reputation.
Tow wiring question
Last week I purchased a 97 f-150 4x4 for 1500 off of my cousin. the truck is in beautiful shape. Shines like a champ. I am now wanting to put a reese hitch on it . It has the factory 4 pin on it and regular bumper. I went to the junkyard yesterday I ended up finding a factory hitch for it with factory harness and 7 pin hooked to it with plugs. one big plug and one little plug. Does anyone know if i can hook that one up to my truck or should i just discard it. Now i do relize that depends if the harness is even good. But i figured that i would give it a shot. I want to put a 7 pin on it anyways because i had one on my old truck and then i also want to take my brake control off of my ole f-150 and put it on this one. Any help would be greatly appreciated
art
__________________
1991 F-150 XLT Texas Lariat Edition
Ext Cab 250,000 miles
300 I-6 POWER. MY blood RUNS FORD BLUE!
  #2 (permalink)
Old 05-17-2008, 07:02 PM
Lavern's Avatar
Lavern is starting off with a positive reputation.
It should hook up the same way on your 97 like it did on the junk yard truck. Mine cuts into my tail lights. You can also buy adapters so you can run 7 pin and 4 pin.
  #3 (permalink)
Old 05-17-2008, 07:03 PM
Lavern's Avatar
It should hook up the same way on your 97 like it did on the junk yard truck. Mine cuts into my tail light wire harness. You can also buy adapters so you can run 7 pin and 4 pin.
  #4 (permalink)
Old 05-17-2008, 09:34 PM
steve(ill)'s Avatar
steve(ill) is starting off with a positive reputation.
the harness to the back end has a big plug between the rear tire and gas tank up in the body frame. the back harness plugs into that and goes to the rear lights and hitch. you can unplug the present harness and just plug in your new harness, if it is good.. ther rear harnesses were two different types, 4 pin and 7 pin. you might need a relay or two up under the hood in the fuse box to get power to the 7 pin hitch for trailer brakes.
__________________
2001 SuperCrew 4 x 4 5.4 XLT - 165,000 miles
2002 Explorer 4 x 4 4.0 XLT - 100,000 miles
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
