the harness to the back end has a big plug between the rear tire and gas tank up in the body frame. the back harness plugs into that and goes to the rear lights and hitch. you can unplug the present harness and just plug in your new harness, if it is good.. ther rear harnesses were two different types, 4 pin and 7 pin. you might need a relay or two up under the hood in the fuse box to get power to the 7 pin hitch for trailer brakes.
__________________
2001 SuperCrew 4 x 4 5.4 XLT - 180,000 miles
2002 Explorer 4 x 4 4.0 XLT - 110,000 miles
