Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 01:02 AM
345window is starting off with a positive reputation.
lowering 70 f100
Hi does anyone have a photos of their 67-72 lowered front suspension an under side shot to show the installed beams and tierod relocators.
Thanks
  #2 (permalink)
Old 05-18-2008, 03:24 PM
carcrafter22 is gaining momentum as a positive member of FTE.carcrafter22 is gaining momentum as a positive member of FTE.
I dont have any pics of a lowered stock suspension but I have a thread on here installing a 07 model crown vic front suspension with disc brakes and rack and pinion steering for under $400.00 this lowered my truck around 4-5". I have lots of pics of the install which was pretty easy. I would say a weekends worth of work to install the entire front suspension.
__________________
Project Grocery Getter: 67 F100 sc/sb 06 crown vic front suspension and rear axle, isuzu 3.9L diesel, 700R4 trans. Lowered 5" rolling on 18" Looking for 30-32mpg using vegi oil. DIESEL BABY!!
  #3 (permalink)
Old 05-20-2008, 08:31 PM
jhooch's Avatar
jhooch is starting off with a positive reputation.
I have pics of my '66 in my gallery, I'll post the tie rod locator in my gallery tonight. Underneath it is the same as a 67-72. In fact, my spindles are from a '73.
__________________
Jhooch
'05 Excursion Limited 4X4 6.0 Powerstroke
'77 Bronco 302, NP435
'76 F250 4X4 Crew 360, 4-sp (will be Powerstroke)
'66 F100 4X2 LB Custom Cab 428, C6
'66 F100 4X2 SWB Custom Cab, 352, 3sp.
'62 F100 4X2 LB Custom Cab Uni, 262, 4-sp
'64 Ford Galaxie 500 2dr HT
'63 Ford Galaxie 500 2dr HT
  #4 (permalink)
Old 05-21-2008, 12:14 AM
jhooch's Avatar
Pic of tie rod relocator installed now in my gallery.
__________________
Jhooch
  #5 (permalink)
Old 05-21-2008, 01:25 AM
Hi jhooch thanks for the pics I just installed my kit it is a drum brake relocator, when you installed your aim beams did you have a lot of toe out, I was not to impressed w/the relocator kit I had to ream out the tie rod hole to get them to fit and the 2nd mounting point that has to be drilled did not even touch the steering arm I had to heat and bend it to make it fit and it would have been nice if my kit came w/some kind of instructions even though its a pretty straight forward install well enough of the b@#^*ing my truck does sit pretty awsome now I also lowered the back 5 inches now to finish sanding for paint
  #6 (permalink)
Old 05-22-2008, 12:59 AM
jhooch's Avatar
I haven't aligned mine yet, still sorting out the minor details on the disc brake swap (lines, etc.) and power steering install. I had about the same experience on the tie rod relocators. I wish the unit would have been 1 piece instead of having to trust 2 welds to steer out trucks.
__________________
Jhooch
  #7 (permalink)
Old 05-22-2008, 01:27 AM
I got back under the truck today I could not adjust the toe out enough after looking I saw the pass. side relocater was about 1-2 inches from tire while the drive side was 1/16 from tire so the only solution was to take off/heat and bend the drive side steering arm in to the same dist. as the pass side which allowed me to get the 1/8 toe in I needed I got nothing but the run around from AIM I feel really bad for the young guys who may try to install this kit as a first project
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
