Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 12:36 AM
oem78 is starting off with a positive reputation.
clutch bracket interchange
My 1979 F150 4x4 300 6cy 4 spd. clutch pedal is wearing the round hole into an oval hole at the pivot point up under the dash. I pulled clutch bracket out of a 1978 or 1979 F150 with a 300 6 cy with a 4spd tranny but it was a 2wheel drive. Are the brackets the same will these parts interchange? What should I look for ? The trucks are the same except 2wd and 4wd.
  #2 (permalink)
Old 05-17-2008, 09:13 PM
4x4 Bart is starting off with a positive reputation.
I took mine out and welded the hole where it was worn then ground the hole back into shape with a dremel. The weld is much tougher than the base metal.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
