That would be my take as well. Head gaskets can also be taken out by the cdr not being serviced, and oil getting through it into the intake, which then makes the back two cylinders run hotter than the rest. Expect the main seals to be leaking as well, especially if it has sat for a while. Front isn't a big deal, rear requires the trans to be dropped to get at it.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles, holley red electric pump
the other workhorse 92 F350 2wd crew cab, 4.10 rear axle, 92 6bt Cummins, A518 auto (for now)with Gear Vendors overdrive
the project: 77 F250 Camper special 400 4 speed
Iowa Chapter leader
Come on down and join us in the Iowa chapter, or your own local chapter!!
