Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 12:33 AM
ravedaber is starting off with a positive reputation.
84 F250
I just got an 84 F250 6.9, my first. The price was right, all I had to do was haul it off. It's still a good solid truck as it's been in the NV desert it's whole life. Everything appears to be original under the hood. Got it from the original owner, it has 280k miles and needs a new head gasket, which had been replaced 100k ago. Should I fool with the head gasket and squeeze some more miles out of it, or is it due for a rebuild anyway. The previous owner did an excellent job on maintenance and never hauled anything heavier than a medium sized camper occasionally. I know it's ultimately a judgment call on my part but just wanted an opinion from you guys. By the way, I really enjoy reading all the posts on here, thanks.
  #2 (permalink)
Old 05-17-2008, 05:22 AM
PLC7.3 is starting off with a positive reputation.
Head gaskets are a normal maintenance requirement on the OEM 6.9....... Head bolts need to be replaced as they were the culprits........ Bolts or studs...... studs are better and almost same price as new bolts..... just a bit more......
The engine is at about half life........if as you say full maintenance has been kept up.
Valve seals are in need of upgrading since they allowed to much oil to bypass, there are many small things that you can improve....... others will add their info for sure.
__________________
93 F250 SC 4x4 E4OD 355LS
  #3 (permalink)
Old 05-17-2008, 06:46 AM
fellro86's Avatar
Iowa Chapter lead
fellro86 has a very good reputation on FTE.fellro86 has a very good reputation on FTE.fellro86 has a very good reputation on FTE.fellro86 has a very good reputation on FTE.
That would be my take as well. Head gaskets can also be taken out by the cdr not being serviced, and oil getting through it into the intake, which then makes the back two cylinders run hotter than the rest. Expect the main seals to be leaking as well, especially if it has sat for a while. Front isn't a big deal, rear requires the trans to be dropped to get at it.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles, holley red electric pump
the other workhorse 92 F350 2wd crew cab, 4.10 rear axle, 92 6bt Cummins, A518 auto (for now)with Gear Vendors overdrive
the project: 77 F250 Camper special 400 4 speed
Iowa Chapter leader
Come on down and join us in the Iowa chapter, or your own local chapter!!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
