Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 12:16 AM
stranskydw is starting off with a positive reputation.
busted
My f250 4x4 is busted.
All I know right now is the engine (5.7 liter) is reving up and down and wants to stall. Running very ruff.
My son was drive at hiwayspeeds, when he got off he strated experiencing the symptoms.
seems like the timing chain has jumped a tooth.
Thoughts?
  #2 (permalink)
Old 05-17-2008, 12:30 AM
Animalistic's Avatar
Animalistic is gaining momentum as a positive member of FTE.
Any codes? Does your "Check Engine" light come on. This is the first place to check. This will tell you where to look.
__________________
1991 F-350 5.8 (351) C-6 2WD Longbed ~109K
Hukt un Fonix rilly werkt fer mee!
  #3 (permalink)
Old 05-17-2008, 02:13 AM
icrman is starting off with a positive reputation.
And who was he racing when it happened?
The net is full of stories about how cars mysteriously break when the "Kid" was using it.
Ha ha ha. Don't ya remember when you where a "Kid"?
Maybe some bent valves from the high revs? LOL
__________________
1996 F-250, XLT 460 E4OD, Long box, Supercab 4X4, 4.10 Axle Ratio, Camper and tow package.
Self install of: Clifford alarm, B&W Flipover gooseneck hitch, Ride Rite airbags, and compressor system, Prodigy Brake controller.
  #4 (permalink)
Old 05-17-2008, 07:34 AM
deeznuts822 is starting off with a positive reputation.
could have jumped a tooth, line up mark for tdc on balancer and pull the cap. it should be either pointing to the #1 position or #6
  #5 (permalink)
Old 05-17-2008, 11:13 AM
BChance's Avatar
BChance is starting off with a positive reputation.
run your codes.. running up and down and trying to stall, you probably only have something like a Throttle Air Bypass stuck.... run your codes.
Did I mention you should run your codes?
__________________
BChance
Los Alamos, NM
JOIN NEW MEXICO CHAPTER HERE!
"Oderint Dum Metuant"
  #6 (permalink)
Old 05-17-2008, 09:05 PM
thanks guys, I didn't have a chance to do anything today. Yes I plan to run the codes.
thanks deez I was wondering how to check to see if it had jumped a tooth.
  #7 (permalink)
Old 05-19-2008, 07:39 AM
I was also told if the chain had jumped a tooth the truck would not run at all and the engine would spin freely due to the lack of compression.
And no i still havenot been able to look into the problem. I am hoping to take it to have the codes read tonight.
  #8 (permalink)
Old 05-19-2008, 09:54 AM
Conanski's Avatar
Conanski is gaining momentum as a positive member of FTE.Conanski is gaining momentum as a positive member of FTE.
Forget about the timing chain jumping a tooth that's nearly impossible, the chain would have to be worn so bad it would have been hitting the timing cover and making a lot of noise for a long time.. you'ld know it was bad. Check your codes and look for more obvious things like arcing plug wires or a failing fuel pump.
__________________
Paul O
1990 F150 4x4 XLT Extended Cab 5.9(351 .030" over), FMS SEFI MAF Kit, Ported E6s, Crane 444232,
AOD, TransGo Shift Kit, 3:55LS, Flowtech Longtubes, TweecerRT
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
  #9 (permalink)
Old 05-19-2008, 11:23 AM
RDJ184's Avatar
RDJ184 has a great reputation on FTE.RDJ184 has a great reputation on FTE.RDJ184 has a great reputation on FTE.RDJ184 has a great reputation on FTE.RDJ184 has a great reputation on FTE.
Hey guys the revving up and down sounds like a vacume leak start looking around the intake
__________________
RANDY 06 6.0 4X4
  #10 (permalink)
Old 05-20-2008, 07:05 AM
A status check here.
The check engine light is not on.
no codes yet.
ruled out timing chain. (no noise has compression)
fuel pump is ok (switched from front to back tank without a change in symptoms)
I hope to at least check for a vacuum leak around the seal tonight. Aparently these engines have a tendency to blow out the seals around the intake.
  #11 (permalink)
Old 05-21-2008, 07:04 AM
No leak around the intake but there was a component (I don't know what it is or does) that has vacuum connections. it was making a humming noise after the truck was shut off, sounded like a electircal connection hum or an old stereo hum. I took it off cleaned it internally with PB Blaster and the little filter on top. reinstalled.
also cleaned all fuss stabs in the fuss box under the hood and battery posts per someones suggestion.
Checked the timing with a light and adjusted it, tried at 0 degrees and 10, did not seem to matter. Where I thought the mark should be the truck ran like crap, hafe way down the scale it runs great.
All syptoms are gone except the check engine light, I got to Auto Zone just as they closed so hopfully today I will get that done or have to do some counting.
  #12 (permalink)
Old 05-21-2008, 11:25 AM
MisterDave2 is starting off with a positive reputation.
My first thought also was a vacuum leak or bad/dirty device. I had to go through all of mine, taking the hoses on and off till I found the culprit, cleaned it up and it was fine after that. Don't forget to charge your kid $12 for something/anything you can make up, keeps them cridders in check. I just made mine buy his own $105 tire that he wrecked, he'll be more careful next time........Won't he? HA, who am I kidding!
  #13 (permalink)
Old 05-21-2008, 01:22 PM
good idea, I am making them do some of the mundane maintance so maybe they will care a bit more.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
