1994 F-350 4x4
Has anyone rebuilt there transfer case?
Mine seems to be doing some slipping and/or clunking when Im stuck.
Its like theres a broken gear that only catches sometimes?
i just got don rebuilding my transfer case today wasnt that big of a chore really just take your time and patience i will be posting the pics i took durring the process to maybe help some. my truck had the Borg Warner 1356 transfercase in it dont know if that means anything to you there is a number ont the back of your transfer case you will have to clean it off to read it but the first 4 nums will tell you wich it is. anymore questions just give me a shout and i will try and help out. good luck
__________________
95' PSD single cab long bed 4X4 manual tranny.
New DP, 5" exaust with 5" stainless tip Sounds great no cat no muffler! Tymar intake for some bling ha! Superchips micro tuner feels good
SOON TO COME stage II's, tony wildman or dp tuner, Big oil and a pillar gauges EGT's and Boost maybe new fuel system.
1997 F-350 PSD Auto 257K
Tuned by Tony, Built by ME!
TDP/TW tunes
AD injectors
6.0 IC
17* HPOP
Tru-cool
The Cure
ESE Eliminator
6" stacks
4 Wh disc brakes
1/4 mile-14.59@88 MPH
Click the Picture for wiring diagrams, tech info and Pictures!
How does the PTO work? Does it spin all the time or is there another lever to engage it? I think it would be good to have for when and if you needed it. Kinda like the gun thing. I would rather have it and not need it than need it and not have it. Anyways does it come out the front or rear? I would assume rear.
The PTO will spin any time the trans is in gear. If needing stationary PTO put the t-case in neutral. The PTO mount is on the right side of the t-case.
TDP/TW tunes
AD injectors
6.0 IC
17* HPOP
Tru-cool
The Cure
ESE Eliminator
6" stacks
4 Wh disc brakes
Tj
That PTO setup could come in handy when the bio system is up and running.
Would be a nice to be able to pump the dirty oil or transfer of the bio after.
I have racked my brain for a use for the PTO option in my truck but I just can't find a good use for it. To collect WVO I am using a super sucker using a 100 gallon propane tank that I will pull vacuum on with 1 of 2 pumps I have (12 or 110 volt). I did think about running a hydraulic pump off it then I could power what ever I want with hydraulic motors but to me its not really worth the effort.
TDP/TW tunes
AD injectors
6.0 IC
17* HPOP
Tru-cool
The Cure
ESE Eliminator
6" stacks
4 Wh disc brakes
Well my truck is a 250 and i had the 1356 t-case so i dont know there. i did have a truck that had a hydrolic wench that was one of the meanest wenches i had ever seen. pulled the truck up to a big tree front bumper first and pulled a smaller tree about 8" in diameter out of the ground. thats one option but who needs that.
__________________
Well that shoots that theory. Must depend on the day of the week the truck was built. LOL I don't know.
TDP/TW tunes
AD injectors
6.0 IC
17* HPOP
Tru-cool
The Cure
ESE Eliminator
6" stacks
4 Wh disc brakes
IIRC the year of the truck determines what transfer case it has and not F250 vs F350 or auto vs manual. 95 and earlier have 1356's and 96 and laters have 4407's.
4407's also have a flange on the rear output that the u-joint bolts to and the 1356's have a yoke that is splined to the output shaft.
Mine is the spline into the output shaft so I guess its a 1356.
