Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 11:46 PM
SmokeBlower's Avatar
SmokeBlower is starting off with a positive reputation.
P1351 & P1359 OBD2 Codes on a 1996 351
I have replaced the computer, TFI Module (twice Motorcraft brand), the coil, the distributor, spark plug wires, and spark plugs.
The engine runs great. It is in a 1996 Bronco.
Here are the OBDII codes:
P1351
P1359
These codes are not causing any problems for the truck to run, but I cannot get it inspected in my county if it is throwing any code. I need help!
Anybody have any ideas on how to fix this problem?
__________________
96 Bronco 351W
94 F350XLT 4DR 4x4 351W
93 2.3 Mustang (daily driver)
01 PT Cruiser (wife daily driver)
85 F350 4DR 4x4 DRW Turbo 7.3 IDI (parts for 94)
  #2 (permalink)
Old 05-17-2008, 12:41 AM
Animalistic's Avatar
Animalistic is gaining momentum as a positive member of FTE.
I went through my code book and my Chilton's and I could not find your codes. There was nothing in the 4 digits. You may have either the wrong year or I am not smart enough to find the codes. My Chilton's does go to '96 and has all the codes for OBD-1 so you may want to post in the '97 forum. They should be able to send you in the right direction. Good luck.
__________________
1991 F-350 5.8 (351) C-6 2WD Longbed ~109K
Hukt un Fonix rilly werkt fer mee!
  #3 (permalink)
Old 05-17-2008, 06:46 AM
Lazy K is starting off with a positive reputation.
Here`s what I found 1351-Ign. diagnostic Monitor Circuit input failure and 1359 Spark Output circuit fault. I would have thought you replaced just about everything to correct the codes. Perhaps Conanski will reply and throw some light on your problem.
  #4 (permalink)
Old 05-17-2008, 08:55 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
One of the sources I found said P1359 is the crank positon sensor, this is something unique to the '96 motors. It's down on lower passenger side of the motor near the harmonic balancer.
__________________
Paul O
1990 F150 4x4 XLT Extended Cab 5.9(351 .030" over), FMS SEFI MAF Kit, Ported E6s, Crane 444232,
AOD, TransGo Shift Kit, 3:55LS, Flowtech Longtubes, TweecerRT
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
  #5 (permalink)
Old 05-17-2008, 01:26 PM
Do you think I should just replace it with a new one or clean the old one?
__________________
96 Bronco 351W
  #6 (permalink)
Old 05-17-2008, 02:55 PM
cheese5.0 is starting off with a positive reputation.
this may sound stupid but did u disconnect the battery to reset the computer when you changed out those parts?
  #7 (permalink)
Old 05-17-2008, 10:23 PM
No I did not do that, but I did clear the codes using my OBD2 reading tool. Should I disconnect the battery or is clearing the codes with the tool the same end result?
__________________
96 Bronco 351W
  #8 (permalink)
Old 05-18-2008, 06:51 AM
Clearing the codes with the reader is the correct way-means the computer does not have to re-learn. Conanski may have hit the nail on the head. I don`t think cleaning the sensor is the answer, however, I think it is possible to test to test it. I don`t know how but if you go to autozone.com there may be some information on testing.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
