I went through my code book and my Chilton's and I could not find your codes. There was nothing in the 4 digits. You may have either the wrong year or I am not smart enough to find the codes. My Chilton's does go to '96 and has all the codes for OBD-1 so you may want to post in the '97 forum. They should be able to send you in the right direction. Good luck.
Here`s what I found 1351-Ign. diagnostic Monitor Circuit input failure and 1359 Spark Output circuit fault. I would have thought you replaced just about everything to correct the codes. Perhaps Conanski will reply and throw some light on your problem.
One of the sources I found said P1359 is the crank positon sensor, this is something unique to the '96 motors. It's down on lower passenger side of the motor near the harmonic balancer.
__________________
Paul O
1990 F150 4x4 XLT Extended Cab (Currently undergoing a heart transplant)
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
No I did not do that, but I did clear the codes using my OBD2 reading tool. Should I disconnect the battery or is clearing the codes with the tool the same end result?
Clearing the codes with the reader is the correct way-means the computer does not have to re-learn. Conanski may have hit the nail on the head. I don`t think cleaning the sensor is the answer, however, I think it is possible to test to test it. I don`t know how but if you go to autozone.com there may be some information on testing.
