Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 10:48 PM
jcoiler is starting off with a positive reputation.
possible franken truck 77 150 + 79 bronco
I have a 77 f150 with a tired 351m I am getting a 79 bronco with a built 400 I am sure I am going to put the 400 in the f150.
What else should I transplant from the bronco to the f150 to make it better?
I need some measurements I know the wheel bases are different but I want to put the bronco body on the f150. I know I will have to extend the body/do a graft. Possibly use a crew cab to make up the extra space.
I could use some body frame measuements so i can dream. I dont wan't to change the frame.
bronco Back of wheelwell to bumper?
Overall length of bronco body?
Length of crewcab bumper to back of cab?
Or advice from someone that has done this.
Thanks,
Jason
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-17-2008, 02:23 AM
jokerforever is starting off with a positive reputation.
If the Bronco has them I would defiantly use the sway bars. The dual shocks up front if could be a nice upgrade too. Some Broncos had larger fuel tanks that might change over. But other than that both chassis are about the same except for the length. As for your body swap, I think you’re opening a can of worms you don’t want to get into. I’m going to resist my urges to tell you all the reasons why it’s a bad ideal and just say good luck with what ever your goal is.
__________________
It was then known, that all would be well, unless it wasn't. -PILZ-E
1965 Mustang coupe 250 six
1965 Galaxie "fastback" 390
1978 Mustang II v8 car but not stock-wanna race?
1978 F-150 351M 4x4
1998 Ranger 3.0L 4x4
2001 F-350 Reg cab V10 4x4--FOR SALE!!
  #3 (permalink)
Old 05-17-2008, 06:32 AM
pauls painting is starting off with a positive reputation.
so you want to build a centerian(sp) go to fourdoorbronco they have some info if your thinking about doing this . i think they are cool kind of like suburban
  #4 (permalink)
Old 05-17-2008, 10:08 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4 is gaining momentum as a positive member of FTE.
whats wrong with the bronco frame? unless you have lots of time, and can fabricate well, don't start chopping anything. i have done it all, whats your final outcome goal? a regular bronco on an f150 frame? why? If youre going to build a 4 door bronco, then just chop the frame in half and weld in extensions, lots of fish plates and extra bracing. this is by no means an easy task, it takes lots of time measuring everything. dont destroy the bronco in the process, there arent many of the 78-79s left, and are worth more than the f150. any q's just ask. i'm confused on your question. lol. measurements? 4 door bronco is 33 and a half inches longer than a stock bronco.
__________________
STOP GLOBAL WHINING!
  #5 (permalink)
Old 05-17-2008, 11:36 PM
Ahhh the 150 frame will be too short. I love broncos but then I love the PU. Quick history my dad always had a bronco from work (used it for my first real date) I had a 73 highboy v8 propane in high school. Well I guess I will keep both. Rebuild the 351 maybe make it a 400 and nice out the bronco with the c6 over the next year for trips and camping by taking it down to the frame. Put the 400 in the PU to handle the 36s I have on it with the 4 speed for off roading. and the 88 corolla for commuting so I can spend more on the fords.
Overtime here I come as long as the wife dosen't hang me before I get to go to work.
Thanks for the help.
Jason
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
