Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 10:45 PM
dgassett is starting off with a positive reputation.
Unhappy bed assembly question here guys
The passenger side of my bed is pretty well destroyed. Frame is straight. I was wondering if I can take apart the bed in sections without having to cut. I found a short bed at the junk yard with the passenger side messed up. The junk yard wond let me cut the bed there. Funny thing is they sell the bed for $250.00 and a bed side for $50.00. So if they sell just the bed side I am hoping it can come apart without cutting.
  #2 (permalink)
Old 05-16-2008, 11:38 PM
Red69 is starting off with a positive reputation.
If you are talking about a fleetside bed it is welded. You either drill out the spot welds or just cut it.
  #3 (permalink)
Old 05-17-2008, 08:14 AM
blue68f100's Avatar
blue68f100 is starting off with a positive reputation.
Like red said the bed is welded. You can get a spot weld removal drill tool. It cuts around the weld allowing you to seperate the pieces with out have to drill the weld itself. The weld it's self is real hard. Then once you have the alignment you do a rosett weld. This is basic a weld that fills in the hole.
__________________
68 F100, mod 360, C6 Auto
  #4 (permalink)
Old 05-17-2008, 02:13 PM
limegoldf100 is starting off with a positive reputation.
It's also difficult because these beds (unlike the 73 and up) are only partially double-wall. The top portion is a single panel running from a seam and bending over for the straight upper part of the bed. The lower panel forms the outside from the seam to the bottom and folds sharply at the seam and back down to the bed floor on the inside.
__________________
71 Explorer 351W/C4
72 Sport Custom 302/C4
  #5 (permalink)
Old 05-17-2008, 02:45 PM
Thanks guys, so if I remove the spot welds the side of the bed itself should come off. No it is not a step side. I guess that means I got a tough job ahead of me.
Do you think it woud be easier to just get the piece of sheetmetal from LMC and replace what is bad? I can't weld but I have a buddy that says he could.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
