the other day me and my dad pulled his race car to the track and when we left my truck running and we was fueling his race car up and i walked beside my truck and noticed the exaust blowing on my leg and so i felt with my had and it was pretty hot so i think i might need new exaust or some thing do yall have any ideas on how big i need to go?
Are you saying you need new exhaust because it was leaking, or because it was hot? Without a turbo, 3" to 3 1/2" is adequate.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles, holley red electric pump
the other workhorse 92 F350 2wd crew cab, 4.10 rear axle, 92 6bt Cummins, A518 auto (for now)with Gear Vendors overdrive
the project: 77 F250 Camper special 400 4 speed Iowa Chapter leader
Come on down and join us in the Iowa chapter, or your own local chapter!!
I got mine so hot once that the plastic mudflap got a curve formed into it... The tmep isn't as indicative as how the engine behaves. At idle, it shouldn't be overly hot, but there will be heat all the same.
__________________
That will tell the whole story. Typically, the exhaust will be hot enough to be uncomfortable for sure.
__________________
