05-27-2008, 06:58 AM
I believe the selector valve switches when it gets pressure from one in tank pump or the other.
When you say that the in tank pumps are not running, you really need to get under there and check to see if you have power. If you have power and it's not running, you have a bad pump. If you have no power at the connector, it's an electrical issue, maybe the selector switch.
You need to track this down, and it doesn't cost you any more money.
__________________
1995 F150 4x4 SC 302 4R70W MAF
