Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 09:35 PM
1awesomehighboy is starting off with a positive reputation.
My Build Up
So i am new to this site and have asked a few questions. But i have never gave any details on my build, so here goes. i have a 1970 F2504x4 that came with a 360 np435 dana 60 rear and a closed knuckle 44 in front with the divorced t case. 205? i smoked the 360 was going to rebuild it but found deal on a 460 so i went that way. i have a d1 block an d3 heads with a stealth intake and rv cam the rest is pretty much stock except the heads had been worked over a lil. my engine guy said good for at least 400 hp. i just bought a 750 double pumper is this going to be a good carb? i want to leave the rest the way it is excpt the seats what is the best way to put buckets in it. i also want to put full power steering and and a dana 44 open knuckle in front with 38-39 inch boggers. thats pretty much it im open to any ideas or suggestions that you guys have
  #2 (permalink)
Old 05-17-2008, 10:02 PM
46069dord is starting off with a positive reputation.
sell the DP holley you don't need it DP is a race thing
  #3 (permalink)
Old 05-17-2008, 11:34 PM
Truckin4life has a good reputation on FTE.Truckin4life has a good reputation on FTE.Truckin4life has a good reputation on FTE.
With that torque from the 460 and the 39" tires your axle will be the weak link... I would go to a d60 atleast...
__________________
Don
Stg's Minions: 12 volt specialist
1995 f-250 ext. cab, lb. 4x4, 5.8 5 speed. Performance mods, and a heavy foot.
Quote:
Originally Posted by STGFordCrazy04 View Post
X2 and hes not talking about truck nuts
Welcome to the Minions house.....Giving correct answers since 2007.
  #4 (permalink)
Old 05-18-2008, 12:51 AM
345window is starting off with a positive reputation.
Hi there is no reason you can not run a dp they are great carbs and not just for racing if a person says there no good they are talking from hear say and not experience I have run dp hollys and vac sec. the dps when set up right are awsome for every day use.
  #5 (permalink)
Old 05-18-2008, 02:35 AM
johnboy427's Avatar
johnboy427 is starting off with a positive reputation.
With a heavy truck with giant tires I think you will be a lot happier with a vacume secondary carb. I guess after weeks of changing power valves, jets, and accelrator pump cams you might find the sweet spot on a DP but it would be easier to just run vacume secondarys.
-Johnboy
__________________
-1979 F-250 4X4 400 4spd
-1989 Bronco 300six swapped in ZF 5spd
-1967 Mercury Comet Sports Coupe
  #6 (permalink)
Old 05-24-2008, 12:45 AM
i went with the dp cause i figured with vac secondaries thats just one more thing to go wrong and my dad is an old school holley guy so he is going to help me get it set right. and i really want a hp 60 but there hard to come by so i think im going to settle with a hd 44 and build it later on down the road. and oh yea this started out as a cheap project but we all know how that goes i hev five grand in a truck that does not even fire
  #7 (permalink)
Old 05-31-2008, 09:44 PM
i got the old beast fired up last weekend after i worked out some issues with the msd and got it timed right (180 out) it popped rite off. sounded like **** though sounded like a v-6 stang. could not figure out why then like a ton of bricks it fell on me. the open vaccum port on the intake. what a tard. plugged it up and settled down. sounds so Fing sweet
  #8 (permalink)
Old 06-01-2008, 12:14 AM
freejay is starting off with a positive reputation.
Quote:
Welcome to the Site! That should be a Dana 24 t-case. Supposed to be as tough as a 205. I think you can put a bench or 40/20/40 seat out of any ford pickup up to 96. I put a D44 out of a 76 F250, direct bolt in except for the brake lines I believe.
__________________
Jay
70 F250 Crewcab 4x4 390 5spd-restomod in progress
79 Bronco
96 F150
70 f250-crewcab wheeler
  #9 (permalink)
Old 06-01-2008, 12:19 AM
Double post
__________________
Jay
79 Bronco
96 F150
  #10 (permalink)
Old 06-07-2008, 09:08 PM
thanks man have not messed with it much this week i have been working so hard since december trying to get it going i decided to take a lil break
  #11 (permalink)
Old 06-07-2008, 11:28 PM
Power Smoker is starting off with a positive reputation.
Whatever seats you decide on, make sure the back rest isn't too thick, you'll be crammed into the steering wheel. my favorites are the 40/20/40 from the '96ish full size.
__________________
'03 6.0 w/ streched '72 cclb body, head studs, fire rings, 120 hp DDP injectors, custom SCT tune, AFE stg II intake, 5" exhaust, Snow water/meth, IIS Phat Shaft turbo 37's on 22's, 8" lift, EGR bypass, etc. etc.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
