I'm sure I have nothing to worry about, as the quality which goes into wheels these days is superior, but thought I'd ask anyway.
I've been reading a lot about these ways to increase mileage, including increasing the tire pressure 5 to 10psi. My 2002 Expy has the Sport Appearance Package, which includes the 17" aluminum wheels. In stock form, the sticker on the door jam says tire pressure should be 30psi front and 35psi rear with the P-rated tires. I've upgraded to an LT-rated tire and have been running them at 40psi cold, which is where they ride the smoothest, IMO. Max pressure, as on the sidewall, is 50psi.
If I choose to try and up the pressures to attain more mileage, can my wheels safely handle 45 or 50psi? That's a 15-20psi jump over the stock recomended pressures. I know it's a totally different scenario, but I know adding too much air to a bicycle tire causes a loud "boom".
Will I be safe or should I limit my pressures to around where I am at now with 40psi? Thanks!
