I have a 97 Ford f-250..Early style, like the 96...and it has p 265/75R16 on it when I bought it. I know the truck calls for LT 235 85 R16. Will the lt tire be the same height, or smaller? Thanks
Just incase your wondering the biggest you can fit is a 33 if its a 4x4. Get a nice set of 285/75/16s and you wont have any probs. I have that on my F350 right now as I dont do as much wheelin as I did so the 36's have been retired. The 285's are like a narrow 33. Heres a pic.
Here are the 36's
__________________
1995 F-350 XL 115K 5.8L 351
E4OD B&M Shift Kit
MSD 6A Blaster TIF Coil Taylor Wires
Flowtech LT’s True Dual Header Back
Flowmaster 40’s Dual 3.5” Tips Before Rear Tire
36x12.5x16.5 GY RT/II’s Military Issue
AR Baja 16.5x10 K&N 4.10 Limited Slip
95350XL, what brand of rims do you have in the top picture? Mine look nearly identical but mine have a american racing stick not what ever one you have on yours.
Thanks for the info on the tires guys, Im going with the 285/75/16. But do they have to be LT, because lt take 80 some pounds, and the p,s take 40 some...?
mrhorsepower67: Get the 285's in whatever range you want. There is C,D,E. C is like 40 psi D is like 45-50 I think, and E is up to 80 on some. Just get the ones in the load range you want.
Raider50: The top wheels are AR's. The center caps came with the AR Bajas. There newer AR's.
__________________
E4OD B&M Shift Kit
mr hp.. check the ratings on each brand your considering. I went with the Yokohama Geolander A/T in a 285/75R16, load range D, and it is rated at 3305 lbs per tire. Plenty for the camper I put on it occasionally, and better than some E rated in a smaller size...
