Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 08:22 PM
hornfan is starting off with a positive reputation.
'00 F250 Cruise Control blows fuse
Every time I set the cruise control on my 2000 F250 I blow a fuse. Any suggestions on how I locate the short?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-16-2008, 08:29 PM
F350-6's Avatar
Slow Typing
F350-6 has a great reputation on FTE.F350-6 has a great reputation on FTE.F350-6 has a great reputation on FTE.F350-6 has a great reputation on FTE.F350-6 has a great reputation on FTE.F350-6 has a great reputation on FTE.
Welcome to FTE. Tell us what motor you have since the cruise is different between gas & diesels. Which fuse are you blowing?
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 255,000 & counting. 6637 w/ Pete's armor. Cold air set up for 6637
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
MORE (Military Online RElay)
  #3 (permalink)
Old 05-17-2008, 10:00 AM
I have a V10 gas. And it's fuse number 4 under the hood in the power distribution box
  #4 (permalink)
Old 05-17-2008, 10:17 AM
F350-6's Avatar
Slow Typing
Do you know if the cruise recall has been done on this truck? I show fuse #4 under the hood is
4 20A* Trailer Tow Backup Lamps, Trailer Tow Park Lamps
Does the cruise quit working when this fuse blows? Is this with or without a trailer hooked up?
You can test your cruise control system by doing this:
Self-Test Diagnostics — Excursion, Super Duty
WARNING: This test is a key on engine off (KOEO) test only that is conducted in park only with emergency brake fully engaged.
Enter Self-Test Diagnostics by depressing the speed control OFF switch while turning the ignition key ON, making sure the engine does not start and is not running. The speed control indicator on the instrument panel will flash once to indicate that speed control module entered the diagnostic mode. FIVE ADDITIONAL FLASHES AT THIS POINT INDICATE A DEFECTIVE SPEED CONTROL SERVO. Release the OFF switch.
Press the remaining switches in this sequence: ON, RESUME, COAST and SET/ACCEL.
IF THE "ON" SWITCH IS NOT DEPRESSED WITHIN FIVE SECONDS AFTER ENTERING THE DIAGNOSTICS MODE, THE MODULE TIMES OUT AND THE PROCEDURE MUST BE STARTED OVER.
The speed control indicator lamp will flash as each switch is depressed. Press each switch in the sequence immediately after the indicator light goes out for the previous switch.
A lamp flash with the last button (SET/ACCEL) indicates that the STATIC test passed. If the lamp does not flash with the last button and there are no additional flashes of the lamp, the switch is defective.
If the lamp does not flash with the last button, and additional flashes occur, follow the chart below for trouble codes:
2 Flashes - BPP defective, circuit is defective, brake applied, CPP switch or jumper (if equipped).
3 Flashes - Deactivator switch is open or circuit defective.
4 Flashes - Vehicle speed signal is out of range or circuit is defective.
Immediately after the STATIC test, the speed control servo does a DYNAMIC test by automatically actuating the throttle lever from 8 mm (0.315 in) to 12 mm (0.472 in) of travel from the idle position. During the DYNAMIC throttle pull, observe throttle movement to witness any binding or sticking of the speed control cable and correct connection of speed control cable to throttle lever. Make sure the THROTTLE RETURNS BACK TO IDLE POSITION.
Let me know how many flashes you get (if any) and I'll find the proper pinpoint test to check from there.
Return ignition switch to the OFF position and proceed to the Symptom Chart.
__________________
Chris
  #5 (permalink)
Old 05-17-2008, 02:34 PM
WOW, very thorough response...thank you...
Unfortunately, the speed control light doesn't come on when I do the test you described.
To answer your questions:
- The recall has not yet been performed on the truck
- It blows the fuse when I engage the speed control without the trailer attached. (I have not tried it with the trailer attached)
- The parking lights on the trailer do not work even with a good fuse.
I'm assuming your first comment will be to get the recall service done. Do you believe this will fix the problem?
Neal...
  #6 (permalink)
Old 05-17-2008, 02:42 PM
F350-6's Avatar
Slow Typing
Quote:
Neal...
No, but it will keep your truck from going up in flames. I've seen several pictures here of burned trucks that did not get the recall done.
Does the cruise work and how can you tell you're blowing the trailer fuse by pushing the cruise button?
__________________
Chris
  #7 (permalink)
Old 05-17-2008, 02:54 PM
F350-6's Avatar
Slow Typing
Did you try the self test with a good fuse in the box? If you've got a short in the wiring it may send a signal through the brake circuit. That might explain why the test didn't work. Also make sure you have the parking brake fully engaged for the test.
__________________
Chris
  #8 (permalink)
Old 05-17-2008, 06:47 PM
I set the parking brake and replaced the fuse and the self test still didn't work. I know it's the cruise that's blowing it because I tried to set the cruise while driving without the trailer. The cruise light flashed on and then immediately went out as the fuse blew. The cruise does not work.....Neal....
  #9 (permalink)
Old 05-17-2008, 06:56 PM
F350-6's Avatar
Slow Typing
Try the test without the fuse in place. Your problem appears to be in that circuit so try it without the fuse in place.
__________________
Chris
  #10 (permalink)
Old 05-17-2008, 08:20 PM
OK, the cruise flashes once after switching on. Then when I follow the sequence you outlined, it flashes once after 'on' then does not flash after any of the rest (resume, coast, set/accel). It is not flashing five times after entering diagnostic mode. Bad on right side? Could that cause a short blown fuse?
  #11 (permalink)
Old 05-17-2008, 08:30 PM
F350-6's Avatar
Slow Typing
It does sound like a defective switch, but I don't see how it's blowing the trailer fuse. I'd go ahead and get the recall done then you can start looking at what else you need to chase down. There could be a problem with the buttons themselves or it could be a short in the steering column too.
Here's a link with pics that will show you what's involved if you need to change or fix the buttons. http://www.ford-trucks.com/forums/69...l-removal.html
And here's a link of how one guy fixed his cruise control. http://www.ford-trucks.com/forums/68...3l-diesel.html
I'd also check the wires near your trailer plug and see if you can find the short that's causing your fuse to blow and your trailer lights not to work.
__________________
Chris
  #12 (permalink)
Old 05-17-2008, 08:56 PM
You have been a great help....Thank you Chris......Neal....
  #13 (permalink)
Old 07-04-2008, 12:25 PM
tetsuo73 is starting off with a positive reputation.
I am having problem with my cruise control also. The recall was done on my 03 excursion v10 about 3000miles ago. currently just little over 90,000miles.
I followed the self test and I got 3 flashes after the SET ACCEL.
What would be the next step I should check?
thanks
  #14 (permalink)
Old 07-04-2008, 05:37 PM
F350-6's Avatar
Slow Typing
Try this tetsuo73
__________________
Chris
  #15 (permalink)
Old 07-06-2008, 05:10 PM
Quote:
Originally Posted by F350-6 View Post
Try this tetsuo73
Thanks Chris. I found the problem. For some reason the plug was not connected on the lower side of the brake fluid reservoir. Not sure if the Ford tech just forgot to plug it back in after the recall or what not. But it works again.
thanks for the help.
Ed
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
