Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Expedition & Navigator 1997 - 2002 and 2003 - 2006 models
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 09:10 PM
AWorthington is starting off with a positive reputation.
Squeaky air conditioner compressor
I have a 1998 Expedition XLT 4x4 5.4L. I have a squeaking or squealing sound coming from the engine. After changing the idler and belt tension pulleys the squeal is still there. I now believe it is the A/C compressor. Does anyone have a quick and easy fix for it or do I have to replace it? Of course it looks like the most difficult accessory to get to and replace.
Thanks for the help in advance.
AW
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-16-2008, 11:20 PM
sbclemens is starting off with a positive reputation.
How old and in what condition is the belt?
__________________
98 Expy XLT 4x4 5.4L
  #3 (permalink)
Old 05-17-2008, 12:59 AM
Belt
I believe the belt is relatively new. The engine was replaced replaced two years ago and currently has about 15K on it. The belt has no cracks on it and looks in good condition.
  #4 (permalink)
Old 05-17-2008, 12:22 PM
alloro is starting off with a positive reputation.
If it's the compressor pulley bearings, the noise will go away when you engage the compressor, since the pulley will now be turning along with the compressor shaft.
  #5 (permalink)
Old 05-17-2008, 07:12 PM
bruce381 is starting off with a positive reputation.
its the Clutch spray some oil into the Clutch see it it goes away if not new Clutch
time.
bruce
  #6 (permalink)
Old 05-17-2008, 09:10 PM
slc10844 is starting off with a positive reputation.
Check the condition of the rubber on the crankshaft pulley. If the rubber is deteriorated or coming out the outer ring might be slipping. They will squeal like a loose drive belt.
__________________
08 F-150 FX4 Supercab 5.4 Auto 3.55 LS
  #7 (permalink)
Old 05-17-2008, 09:18 PM
Does it make the noise all of the time or just when accelerating?
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
