Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 05-19-2008, 06:46 AM
Cuda_jim's Avatar
<------Ancient Politician
Cuda_jim has a very good reputation on FTE.Cuda_jim has a very good reputation on FTE.Cuda_jim has a very good reputation on FTE.
Rino, Your battery drain is perfect. No such thing as too low....0 is better but most cars have a small drain for the radio and PCM memory. That's the draw (.01) you are seeing.
x2 with helifixer. Your starter is bad....or the connections to it.
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 05-19-2008, 07:29 AM
WALJON is gaining momentum as a positive member of FTE.
X3 sounds like the starter next time it will not start get someone to turn the key over and you go under the truck and give the starter a wack with a hammer bet it will turn over.
__________________
96 F250 cab & 1/2 4x4 powerstroke
3" down pipe straight exhaust
6637 Intake mod,ccv mod
Glow plugs on a switch
Firestone air rite suspension
203 stat
  #18 (permalink)
Old 05-19-2008, 05:59 PM
Rino Onir is starting off with a positive reputation.
Ill get out and pick up a new starter tomorrow. let you know how it goes
  #19 (permalink)
Old 05-21-2008, 07:35 PM
A new starter has corrected my problem.
Thank you to everyone
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
