Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 07:28 PM
farmer ford's Avatar
farmer ford is starting off with a positive reputation.
351 M and 400 engine
What is the difference between a 351 M engine block and a 400 engine block?
Are they the same just the 400 has bigger pistons and crank? Thanks
__________________
1978.5 F250 stndrd
l. b. 4 speed manual
3" lift 315/75/R16 SXT's
lund moonvisor, custom
paint(dodge blue, viper
silver) home made winch
bumper Warn 9000
diamond plate tool box
1995 F350 4 dr l. b.
PS 5 speed manual
superchips 315/75/R16
SXT's 3" lift, tool box
100gal. transfer tank
6637 intake
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-16-2008, 08:05 PM
mark a. is gaining momentum as a positive member of FTE.
The blocks are the same. They both have 4" bores stock. The difference is the crank and pistons, the rods are the same.
__________________
'79 F250 13" lift 42" Super Swampers
  #3 (permalink)
Old 05-16-2008, 10:12 PM
can a 351 be a 400 with little cost and effort?
__________________
1978.5 F250 stndrd
bumper Warn 9000
PS 5 speed manual
6637 intake
  #4 (permalink)
Old 05-16-2008, 10:22 PM
fastfarmer is starting off with a positive reputation.
Yes, just install 400 crank and pistons and you've got a 400.
__________________
  • 76 F150 Ranger 2wd 352 4sp
  • 91 F250 XLT Lariat 4X4 7.3 E4OD
  • 97 F250 Heavy Duty XL 4X4 351 5sp
  • 99 Mustang GT 4.6 E4OD
  #5 (permalink)
Old 05-17-2008, 02:10 AM
jokerforever is starting off with a positive reputation.
FYI, this is a great swap but if you do it get a set of flattop pistons. The 351M and 400 are good motors but the low compression (and weak, retarded cams) is what gave them a bad name. The best thing about this swap is that flat top and forged slugs are available for the 400 to fix that problem and make the most of those wonderful Cleveland heads. That’s not the case with the 351M as you’re stuck with replacement pistons only. I picked up a 78 last year with a 351M and had plans for a 460 swap. But the more I drove the truck and the more research I did I have now changed my plans for a 400 (or possibly a 434 stroker) upgrade instead. Join them down in the 335 Series Forum and they can help you put together something special.
__________________
It was then known, that all would be well, unless it wasn't. -PILZ-E
1965 Mustang coupe 250 six
1965 Galaxie "fastback" 390
1978 Mustang II v8 car but not stock-wanna race?
1978 F-150 351M 4x4
1998 Ranger 3.0L 4x4
2001 F-350 Reg cab V10 4x4--FOR SALE!!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
