Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1997 - 2003 F150 97-03 F-150, 97-99 F250LD, 7700 & 04 F-150 Heritage
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 07:19 PM
Lavern's Avatar
Lavern is starting off with a positive reputation.
Panel Fan only works on High?
I have a 98 F-150 4x4 with A/C. And I noticed the other day that my fan only works on High and the air isn't really that cold. Anybody know what causes this and how to fix it? Thanks.
  #2 (permalink)
Old 05-16-2008, 10:18 PM
projectSHO89 is gaining momentum as a positive member of FTE.projectSHO89 is gaining momentum as a positive member of FTE.
The fan speed is likely due to a failed blower motor resistor pack.
The air temperature is a different issue, ie, bad knob, busted blend door, or an A/C system that is not working.
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #3 (permalink)
Old 05-16-2008, 11:01 PM
300six1990 is starting off with a positive reputation.
Yup.. 90% of the time the blower resistor is the culprit.. Napa can get it for you.. Should be around $22.. The part number is ECH BR286..
__________________
1990 f150 300/6 M5OD 3.08 2wd..455k.
99.5 Jetta TDI.. Not stock...
94 K5Blazer 6.5TD...
  #4 (permalink)
Old 05-17-2008, 12:17 PM
Lavern's Avatar
Where is the blower resistor located?
  #5 (permalink)
Old 05-17-2008, 12:23 PM
It's located on the passenger's side near the blower motor... Kind of where your right foot would be if you sit in the passenger's side of the truck.. It looks like this..
__________________
  #6 (permalink)
Old 05-17-2008, 06:58 PM
Lavern's Avatar
Alright...Thanks for all the help. I'll go pick one up soon and see if a new one helps. If not I'll be back!
  #7 (permalink)
Old 05-22-2008, 02:41 PM
Lavern's Avatar
Well I got this resistor changed and it works on all fan speed settings but it will only blow air by the windsheild even if i have it on a/c, panel, and all those other ones... would this mean i have to replace the switch?
__________________
-1998 F-150 4x4 4.2L
-2002 F-550 2x4 V8 Power Stroke 42 Foot Boom Truck
-1965 Mustang Coupe 289 Bored Out
-2007 Ford Fusion V6 Fully Loaded
-1947 Ford 1-Ton...paint job is worth more then the truck!
  #8 (permalink)
Old 05-22-2008, 04:59 PM
There should be a vacuum line going into the inside of the truck near the battery. The blend doors are vacuum actuated.. There are a few solenoids for the emission system there as well.. Make sure you have vacuum there at the one line that tucks through the firewall..
__________________
  #9 (permalink)
Old 05-22-2008, 06:29 PM
Lavern's Avatar
Well I found the vacuum line you were talking about and I wiggled it and a few other hoses and wires around and everything seemed to be where it was supposed to be, got in the truck and there was nice cool air blowing on all settings....thanks a lot for all the help!
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
