I have a 98 F-150 4x4 with A/C. And I noticed the other day that my fan only works on High and the air isn't really that cold. Anybody know what causes this and how to fix it? Thanks.
It's located on the passenger's side near the blower motor... Kind of where your right foot would be if you sit in the passenger's side of the truck.. It looks like this..
Well I got this resistor changed and it works on all fan speed settings but it will only blow air by the windsheild even if i have it on a/c, panel, and all those other ones... would this mean i have to replace the switch?
__________________
-1998 F-150 4x4 4.2L
-2002 F-550 2x4 V8 Power Stroke 42 Foot Boom Truck
-1965 Mustang Coupe 289 Bored Out
-2007 Ford Fusion V6 Fully Loaded
-1947 Ford 1-Ton...paint job is worth more then the truck!
There should be a vacuum line going into the inside of the truck near the battery. The blend doors are vacuum actuated.. There are a few solenoids for the emission system there as well.. Make sure you have vacuum there at the one line that tucks through the firewall..
Well I found the vacuum line you were talking about and I wiggled it and a few other hoses and wires around and everything seemed to be where it was supposed to be, got in the truck and there was nice cool air blowing on all settings....thanks a lot for all the help!
__________________
