Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 07:20 PM
guitarguy335 is starting off with a positive reputation.
overhead consol wiring
hi,i have a 2003f250.i want to instal the overhead consol.i have the complete consol,wiring harness and temp sensor.what im looking for is locations of the plugs to plug this in.where does the temp sensor go.it has only a short warnes with it.the other is long with several plugs.any help would be great
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-19-2008, 10:41 AM
Beerstalker's Avatar
Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.
If you could post a picture of what you have it would probably help a lot. I'm guessing since you said the one harness has several plugs it was probably for a truck that had cab lights, as I believe they plugged into the same harness. The plug at the very end should run down to the passenger side kick panel in front of the door and below the dashboard. There should be a matching plug in there. I am not familiar with the temp sensor wiring, but I do know it is normally mounted up in front of the radiator behind the grill. There are a few threads in this forum about adding the overhead computer, you might try doing a search to see if you can find more help.
__________________
2007 F350 Lariat, CC, LB, 4x4
4.5" DR Lift w/35x12.5r20 Toyo Open Country M/Ts
Keystone Restyling Ram Air Hood W/Airaid Intake & Pre-filter
Recon Smoked Cab, Mirror, and Brake Lights
MSD Dashhawk w/A Pillar Mount
Dieselsite Coolant Filter
Lund Eclipse Window Vents
Weatherguard Toolbox
  #3 (permalink)
Old 05-20-2008, 06:42 PM
bpounds's Avatar
NRA
bpounds has a great reputation on FTE.bpounds has a great reputation on FTE.bpounds has a great reputation on FTE.bpounds has a great reputation on FTE.bpounds has a great reputation on FTE.bpounds has a great reputation on FTE.
For the main harness, beerstalker told you spot on. For the temp sensor, the truck won't have that sensor preinstalled, but there should be a spot to mount it behind the grille. I have a picture in my gallery if you want to look at that. I believe you will need to run the two wires yourself. You might find a harness, but I would just wire it up.
Bill
__________________
Folks call me Bill.
Member So.Cal.Chapter
Please pass the GREEN nozzle.
2006 F250 XLT SCLB FX4 4x4 6.0L Automatic, Magnaflow Turbo Back,
Rhino Liner, Retrax Bed Cover, Cab Lights Retro-fit, Overhead Console Retro-fit,
Harpoon Mod, C-Betrs. Pulling Fleetwood Pioneer, 23', 5,200#
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
