Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 05:55 PM
Flea's Avatar
Flea is starting off with a positive reputation.
CPS or what
last night truck stalled after backing up and then restarted no prob.
started fine this morning and kinda kicked a bit while driving down the road as we traveled from Omaha to K.C.
This afternoon after getting back truck stalled a couple of times while driving down the road and then restarted no problem. Then went to local auto parts store and tried to read OBDII codes and none were read and the deivce said that the CEL was on yet I didn't see any light on the truck.
I don't pre-fill my oil filter before installing it. Does this lead a code that I can't erase?
Anyway back to the point,
I tried to clear the codes at all, just trying to see if it would work and help.
Then the truck wouldn't stay running and tach would move while cranking.
I have already d/c the fuel heater and replaced #22 fuse before. I have had the dealership replace the recalled CPS earlier this year.
Truck then re-started after 6-10 times and stayed running for a drive home from the parts store.
I haven't yet replaced the CPS but will or can I rule that out?
Thanks
Flea
__________________
Fletch
________
'97 PSD 4x4 Supercab, E40D, 3.55, 113K miles,
Waste Veg. Oil conversion - GoldenFuelSystems.com
Tymar Intake,ccv mod, 3" DP,Cat delete, muff delete, Cooner 20K mod, TruCool Max Tranny cooler.
... to come
Aeroforce Terminator gauge (Thanks Tim, I have been looking for an all in one gauge).
Truck Pics
  #2 (permalink)
Old 05-16-2008, 06:44 PM
Mark62 is starting off with a positive reputation.
Probably not. What color is the sensor?
Is it black or is it blue?
__________________
On May 20th, a list of the names of over thirty-one thousand scientists (of which 9,000 are Phds) who refute man made global warming was released.
  #3 (permalink)
Old 05-16-2008, 07:05 PM
Flea's Avatar
I haven't pulled it. I think it is grey.
i will have to check tomorrow when I get off work tonight.
Why not CPS?
Must be electrical.
__________________
Fletch
________
... to come
Truck Pics
  #4 (permalink)
Old 05-16-2008, 08:11 PM
c00nhunterjoe's Avatar
c00nhunterjoe has a good reputation on FTE.c00nhunterjoe has a good reputation on FTE.
you cant always trust the autoparts scanners, they are as generic as it gets, most times they wont work right on our trucks.
there is alot of issues with the new replacement cam sensor. if it stalled that many times on you and if it is a cam sensor you should have both codes stored by now, try someone elses scanner
__________________
97 F-250, 4.10's Auto, Superchip, All mods by c00nhunterjoe's performance shop http://community.webshots.com/user/c00nhunterjoe
http://youtube.com/c00nhunterjoe
  #5 (permalink)
Old 05-17-2008, 08:13 AM
Flea's Avatar
What other electrical problems could it be?
Maybe IDM?
Who else could I get to scan for free? The other parts stores have the same scanner?
__________________
Fletch
________
... to come
Truck Pics
  #6 (permalink)
Old 05-17-2008, 08:29 AM
MADVAN is gaining momentum as a positive member of FTE.
Iam with coon try and get the codes pulled.
For now disconnect the CPS and clean the connections with some electrical contact cleaner. Connect and disconnect a few times. Then give it a last spray and connect it with some dielectric grease on the seal.
Its worth a shot.
Bill
__________________
97 4X4 PSD Quigley
Supporter/End user of ShiftSolutions The CURE E4/4R Trans Control. Helping Cancer patients and families. www.fordtransmissioncure.com Video of No OD Bump/Slip Shiftpoint
Special thanks to RacerX www.racerxautomotive.com
  #7 (permalink)
Old 05-17-2008, 10:53 AM
IDMooseMan's Avatar
IDMooseMan is gaining momentum as a positive member of FTE.
I had a transmission shop check and clear my codes for me. Try that.
What issues have folks been having with the gray CPS? I'm not having any problems at all. Now that I've said that, my truck probably won't start and I won't make to the Dyno Day tomorrow.
If the dyno shop will allow it, I'll be checking the results using different resistors for the ICP Resistance mod. Hopefully I can get printouts of each run with the different resistors. I'm also getting a baseline run without any resistor first, then I'll add a resistor for the following dyno runs.
I'm running the 14.7K now and my mileage went UP to 17.7 mpg as of the fill-up yesterday.
__________________
Craig "IDMooseMan" Peters
1997 F-350 XLT 4x4 CC LB E4OD 4.10:1
FPR Shimmed to 70 PSI, 6637 Upgrade, ICP Resistance Mod
USAF SSgt 1983 - 1992
NAHC Life Member
1991 Wilderness 24M
Truck Pictures
FTE Fraternity of Blue Max
  #8 (permalink)
Old 05-17-2008, 12:50 PM
Flea's Avatar
I thought about maybe that was my prob. and that my connectors had come loose with the long heated drive. I will look at it.
Good idea.
I got 17.5 mpg at 80 mph with the 15K resistor.
__________________
Fletch
________
... to come
Truck Pics
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
