last night truck stalled after backing up and then restarted no prob.
started fine this morning and kinda kicked a bit while driving down the road as we traveled from Omaha to K.C.
This afternoon after getting back truck stalled a couple of times while driving down the road and then restarted no problem. Then went to local auto parts store and tried to read OBDII codes and none were read and the deivce said that the CEL was on yet I didn't see any light on the truck.
I don't pre-fill my oil filter before installing it. Does this lead a code that I can't erase?
Anyway back to the point,
I tried to clear the codes at all, just trying to see if it would work and help.
Then the truck wouldn't stay running and tach would move while cranking.
I have already d/c the fuel heater and replaced #22 fuse before. I have had the dealership replace the recalled CPS earlier this year.
Truck then re-started after 6-10 times and stayed running for a drive home from the parts store.
I haven't yet replaced the CPS but will or can I rule that out?
Probably not. What color is the sensor?
Is it black or is it blue?
__________________
On May 20th, a list of the names of over thirty-one thousand scientists (of which 9,000 are Phds) who refute man made global warming was released.
you cant always trust the autoparts scanners, they are as generic as it gets, most times they wont work right on our trucks.
there is alot of issues with the new replacement cam sensor. if it stalled that many times on you and if it is a cam sensor you should have both codes stored by now, try someone elses scanner
Iam with coon try and get the codes pulled.
For now disconnect the CPS and clean the connections with some electrical contact cleaner. Connect and disconnect a few times. Then give it a last spray and connect it with some dielectric grease on the seal.
I had a transmission shop check and clear my codes for me. Try that.
What issues have folks been having with the gray CPS? I'm not having any problems at all. Now that I've said that, my truck probably won't start and I won't make to the Dyno Day tomorrow.
If the dyno shop will allow it, I'll be checking the results using different resistors for the ICP Resistance mod. Hopefully I can get printouts of each run with the different resistors. I'm also getting a baseline run without any resistor first, then I'll add a resistor for the following dyno runs.
I'm running the 14.7K now and my mileage went UP to 17.7 mpg as of the fill-up yesterday.
__________________
Craig "IDMooseMan" Peters
1997 F-350 XLT 4x4 CC LB E4OD 4.10:1
FPR Shimmed to 70 PSI, 6637 Upgrade, ICP Resistance Mod
USAF SSgt 1983 - 1992
NAHC Life Member
1991 Wilderness 24M
