Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 05:54 PM
jimwilsonmasonry's Avatar
jimwilsonmasonry is starting off with a positive reputation.
hpx on the way
just ordered my hpx and i cant wait to get it OH I LOVE PMS
__________________
I have a 96 psd with 283k miles,3:55s, cc ,e4od-shift kit ,2wd,k&n intake 3" dp, c00ns 22k mod shimmed fpr,no cat, hotpedal,140v idm, eot mod,hpx
  #2 (permalink)
Old 05-16-2008, 05:57 PM
Robbgt's Avatar
Robbgt is gaining momentum as a positive member of FTE.
Good deal! you get the solid one or braided? I got the solid one and works great!
-Robb
__________________
97 F-350 XLT 4x4 PSD, E40D, 3.55's, 153K, 6637, 140V IDM, HPX, FPR Shim, Hotfoot, Tymar DP, Dual Exhaust, T/C Lockup mod, new GP's, Stancor GPR.
>>FOR SALE: FTE Classifieds<<
  #3 (permalink)
Old 05-16-2008, 06:13 PM
bigbadwolfe's Avatar
bigbadwolfe is starting off with a positive reputation.
i have the tymar one its braided and works great
__________________
1997 f250HD 5 speed xcab long bed 4x4
tymar intake & hpx
shimmed fpr gutted ebpv
tymar 3x4 dp to 4" cat delete
diy stage 1 140 volt idm
17* hpop ford AIC
IH fuel bowl heater
modded pedestal
coolant filter 203*stat
08 diff cover
1990 f250 351W E4OD
NO SMOG PUMP NO EGR
GIBBSON HEADERS
AIRAID TBI SPACER
K/N COLD AIR INTAKE
9MM FORD RACING WIRES
  #4 (permalink)
Old 05-18-2008, 02:50 AM
i got the one from dieselsite
__________________
  #5 (permalink)
Old 05-18-2008, 02:54 AM
RubberDuck's Avatar
Death Row Inmate #1
RubberDuck has a good reputation on FTE.RubberDuck has a good reputation on FTE.RubberDuck has a good reputation on FTE.
You'll like it for sure.
__________________
RubberDuck
1995 F350 Crew Cab 4x4 dually
DIY Stage 2's
T.E. SD HPOP
Tymar HPX
FPR 70psi
RSB Diesel 140v IDM
Tymar Intake
3"DP to 5" stacks
DP Tuner 2 pos. w/ custom switch
Hot Pedal
Gear Vendors OD
Good bye No.3 I'll miss you.
RIP #17
  #6 (permalink)
Old 05-18-2008, 11:20 PM
mklemin's Avatar
mklemin is starting off with a positive reputation.
Where did you all get yours? i think i would like to get the solid because they braided they say to replace every year. In my head i would think the the solid would last longer. haha there is alot of crazy things in my head not all of them make sense.ha
__________________
95' PSD single cab long bed 4X4 manual tranny.
New DP, 5" exaust with 6" stainless tip Sounds great no cat no muffler! Tymar intake for some bling ha! Superchips micro tuner feels good
SOON TO COME stage II's, tony wildman or dp tuner, Big oil and a pillar gauges EGT's and Boost maybe new fuel system.
  #7 (permalink)
Old 05-18-2008, 11:46 PM
Robbgt's Avatar
KCM Performance: HPX Lines
Thats where I got mine
NOTE: Scroll down until you see the 94-97 HPX line, it's not the first one on the page
-Robb
__________________
  #8 (permalink)
Old 05-19-2008, 01:24 AM
RubberDuck's Avatar
Death Row Inmate #1
I got my braided one from Dale at Tymar.........like 3 years ago. This is the second truck it's been on and it doesn't even have oil around the fittings.
Here's the thing about HPX lines. There are 2 types of failures.
1. Failure to inspect and maintain it... i.e Check the fittings for snug, and oil leaks during a routine oil change, or fuel filter change.
2. Catastrophic failure where it pops and drains your motor possibly starting a fire on the turbo.
In the first example, failure could be avoided by paying attention. If you drive the crap out of your truck and service it like a quick lube place, you deserve the failure, and had no business modifying your truck in the first place.....period. If you see a leak, or loose fitting, persue it. Tighten fitting, check for leak. If it doesn't stop, replace it. Pretty simple.
The second example is in my opinion a rare occurance. Can it happen, YES. But you pretty much accept that risk when you start on your PMS journey.
And all this is just my opinion on the HPX.
There are benifits to both solid and braided lines
Hard line, most likely will never pop. But it's suseptible to leaks from the natural heating and cooling of the motor. When you tighten those fittings, there's no play except for the bending of the tube. However minimal that is, it still happens.
The braided, can flex with heat and motor vibration, but can pop.
The bottom line is that if you stay on top of maintenance, and make it part of your checklist, you shouldn't have a problem. If you don't, it ain't the parts fault.
Hope that helps in some crazy way. LOL
__________________
RubberDuck
DIY Stage 2's
T.E. SD HPOP
Tymar HPX
FPR 70psi
RSB Diesel 140v IDM
Tymar Intake
3"DP to 5" stacks
Hot Pedal
Gear Vendors OD
RIP #17
  #9 (permalink)
Old 05-19-2008, 07:23 AM
sounds good to me rubberduck
__________________
  #10 (permalink)
Old 05-19-2008, 09:21 AM
Neal 97 250's Avatar
Neal 97 250 is gaining momentum as a positive member of FTE.Neal 97 250 is gaining momentum as a positive member of FTE.
I have the solid one and love it. In my opinion about the heating and cooling of the solid line...: It has several bends in it to go around the y-pipe and by the turbo pedestal. Therefore if there is even a slight bit of expansion the bends will allow it to expand and contract. Alot like steam lines at a plant.
Just my opinion.
__________________
97 F250 7.3PSD
X-Cab, SWB, 4X4
5spd, 4.10gears
3.5” DP, 4” Exh.
AFE Intake
FPR,BDP 140v IDM,CCV,HPX
Rosewood Stage II's
6 pos. TW chip, wow !!
'00 Excursion 7.3PSD 4X4
6637 intake
drill/slot rotors
Neal's Pics
  #11 (permalink)
Old 05-19-2008, 12:44 PM
foxracing0934's Avatar
foxracing0934 is starting off with a positive reputation.
I have a solid one and it works great, I got mine from itpdiesel.com. This site has a bunch of good stuff and they are fairly reasonably priced.
__________________
97 F-350 w/74,*** miles
DP Tuner F5 chip (40,80,100,120)
S.S. HPX Line
3in down pipe
4in MBRP w/o cat
65 psi FPR
Dipricol Gauges (Tranny, EGT, Boost)
Soon to Come:
DIY Sage 1's or 2's(???)
6.0 Spearco Intercooler
H2E Turbo
6637 Intake
Mickey Thompson MTZ's
  #12 (permalink)
Old 05-19-2008, 01:05 PM
Mine came from ITP as well
__________________
97 F250 7.3PSD
X-Cab, SWB, 4X4
5spd, 4.10gears
3.5” DP, 4” Exh.
AFE Intake
Rosewood Stage II's
6637 intake
drill/slot rotors
Neal's Pics
  #13 (permalink)
Old 05-19-2008, 02:09 PM
RÖENTGEEP's Avatar
RÖENTGEEP is gaining momentum as a positive member of FTE.
Wink
Well in theory, the best way for the HPX is connecting the rear most ports?, but in the drivers side is almost impossible, so you choose the next want in front in that side, and thats the case in the TYMAR HPX, and not in the case of the solid one; other advantage IMHO of the Tymar is that you change the 90* elbow fitting for one straigt one, when you move the stock oil line to the front. Maybe that doesnt mean to much and just theory but could be.
__________________
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 142K.
DIY air intake and exhaust brake. Tymar Hypermax DP 3-3.5" ceramic coated; gutted Kitty; Tymar HPX; GPR switch; upgraded headlight harness; Isspro gauges; 14.7K cOOn´s mod; shim FPR; tranny coolerM CCV mod.
«Primum non nosere»
  #14 (permalink)
Old 05-19-2008, 03:12 PM
any body have a good pic of the best place to put it
__________________
  #15 (permalink)
Old 05-19-2008, 06:00 PM
RÖENTGEEP's Avatar
Quote:
Here are some pics for the Tymar HPX.
CLICK HERE
__________________
«Primum non nosere»
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
