Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 05-22-2008, 07:12 AM
jimwilsonmasonry's Avatar
jimwilsonmasonry is starting off with a positive reputation.
got my hpx put in, im happy with it, not much of a difference with anything but im sure glad its on there
__________________
I have a 96 psd with 283k miles,3:55s, cc ,e4od-shift kit ,2wd,k&n intake 3" dp, shimmed fpr,no cat, hotpedal,140v idm,hpx,tw 6 pos chip
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 05-22-2008, 10:37 AM
ono_55 is starting off with a positive reputation.
When you order the Tymar HPX line do you get the fitting to change the line you have to move?
__________________
1997 F250 XLT CC 4X4 4.10LS E4OD 240K(AB Cali Truck)
18K MOD
TYMAR
3'' DOWN PIPE
CAT DELETE
2" LEVELING
EGT,TRANS,BOOST,WATER,OIL,OIL TEMP,VOLTS
285/75/16 MASTERCRAFT COURSER CT'S
SONNAX VALVE and SPRINGS
30,000 lbs TRANS COOLER
  #18 (permalink)
Old 05-22-2008, 12:25 PM
Flea's Avatar
Flea is starting off with a positive reputation.
I put in my HPX and shortly thereafter I found a leak from the HP oil line going into the rear pass side head.
I wonder if the increase in pressure caused this?
Look out.
__________________
Fletch
________
'97 PSD 4x4 Supercab, E40D, 3.55, 113K miles,
Waste Veg. Oil conversion - GoldenFuelSystems.com
Tymar Intake,ccv mod, 3" DP,Cat delete, muff delete, Cooner 20K mod, TruCool Max Tranny cooler.
... to come
Aeroforce Terminator gauge (Thanks Tim, I have been looking for an all in one gauge).
Truck Pics
  #19 (permalink)
Old 05-22-2008, 12:38 PM
i have absolutely no leaks it went together easy and quick and i think all the air is outta the system now to i do like the mod alot it does seem to make everything run smoother
__________________
  #20 (permalink)
Old 05-22-2008, 12:39 PM
fluidp is starting off with a positive reputation.
Made mine from adaptpors and hose and fittings in stock. the adaptors I used were
#5 ORB to #6 JIC (5/16" straight thread to 3/8" JIC flair ) to conect to the hose couplers. They cost about $1.50 ea. Then I made a hose assembly with a 90 deg jic fitting on one end and a straight fitting on the other end. Cost under $10 for the works. Oh and the working preasure for the hose assembly is 4800 psi and a burst preasure about 18,000 psi.
Regular checks to make sure everything is good is just part of my routine.
__________________
95 F250 S/C 4x4 7.3 e40d
3" down pipe - 4" no cat or muff
diy intake 6637
hpop x over
auto meters
To Do: fpr shim , coon's 10k, 140v mod
66 F100, CC
Bone ASS Stock
Wifes Ride,
  #21 (permalink)
Old 05-22-2008, 07:43 PM
Flea's Avatar
Correction my leak was from the rail that is cast into the head, that plug on the rear of the pass. side is what was leaking.
__________________
Fletch
________
... to come
Truck Pics
  #22 (permalink)
Old 05-23-2008, 12:17 PM
RÖENTGEEP's Avatar
RÖENTGEEP is gaining momentum as a positive member of FTE.RÖENTGEEP is gaining momentum as a positive member of FTE.
Quote:
When I bougth mine, the line come with all the fittings you need.
__________________
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 142K.
DIY air intake and exhaust brake. Tymar Hypermax DP 3-3.5" ceramic coated; Tymar HPX; GPR switch; upgraded headlight harness; Isspro gauges; shim FPR; tranny cooler; CCV mod; 4" stainless Magnaflow; SS 5" tip; no cat; RacerX VB; TW 6p chip.
«Primum non nosere»
  #23 (permalink)
Old 05-23-2008, 01:09 PM
Ok thanks ROENTGEEP. i THINK i'am going to order one.
__________________
18K MOD
TYMAR
3'' DOWN PIPE
CAT DELETE
2" LEVELING
  #24 (permalink)
Old 05-23-2008, 02:45 PM
RÖENTGEEP's Avatar
Thumbs up
No problem. You will not be disappointed (spell?), Im sure.
__________________
«Primum non nosere»
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
