Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > General > General Automotive Discussion
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 05:41 PM
swampthing429 is starting off with a positive reputation.
~off topic~ chevy engine ID
sorry for bringing up a grey area like this, but iam looking at buying an old C-70 (medium duty commercial truck) is a big block gas engine but how do i identify it as a 366,427,454 etc. ??
  #2 (permalink)
Old 05-16-2008, 07:12 PM
scrapyardking is gaining momentum as a positive member of FTE.
Try general auto fourm
__________________
Andy
1977 F-250 400
1978 F-150 302
1986 F-150 302
1994 Ranger 4.0
1972 F-350 tilt bed, 360
1967 F-100 short bed 300
  #3 (permalink)
Old 05-16-2008, 07:46 PM
77Explorer is starting off with a positive reputation.
Quote:
what year is it? can you get the casting numbers off the driver side bellhousing flange?
no matter what it is it will be a TALL deck motor.
  #4 (permalink)
Old 05-16-2008, 09:10 PM
no, cant really get to the casting numbers. providing it is a tall deck i assume it wont fit in a pickup truck eh? thanks
  #5 (permalink)
Old 05-16-2008, 09:27 PM
yeah it will swap in a pickup with no problems
regular is a 9.2 deck and the tall is a 10.2
the 10.2 intake is wider then your typical BBC
the pistons have 3 compression rings and an oil ring and a thick crown
  #6 (permalink)
Old 05-16-2008, 09:38 PM
4x4 Bart is starting off with a positive reputation.
99% were 366cuin
366 3.937 bore x 3.76 stroke
427 4.25 bore x 3.76 stroke
454 4.25 bore x 4.00 stroke
All physically look the same, but by checking the stroke you could eliminate the 454
When they left the factory there was an identification plate somewhere inside the cab (different years in different places) that gave the engine code but by now the engine could be replaced.
  #7 (permalink)
Old 05-16-2008, 10:17 PM
fastfarmer is starting off with a positive reputation.
A few years ago a guy had me put a 366 into his 78 3/4 ton chebby 4X4. He happened to have one and wanted to make use of it. Tall deck not an issue, had to change something on the dist and upper water outlet but I can't remember what. Bottom line - you can use them in a pickup, but I don't know why you'd want to.
__________________
  • 76 F150 Ranger 2wd 352 4sp
  • 91 F250 XLT Lariat 4X4 7.3 E4OD
  • 97 F250 Heavy Duty XL 4X4 351 5sp
  • 99 Mustang GT 4.6 E4OD
  #8 (permalink)
Old 05-17-2008, 10:19 AM
tude is starting off with a positive reputation.
this site may cover it if you can ever get to the numbers
www.mortec.com
in our 2 grain trucks we have a 366 in each of them....one is a screaming motor....the other is a pootch (of course its a tandem missing 1st gear)...... we also have a 427 we pulled out of a semi we bought several years ago.
__________________
southern illinois demolition derby
www.freewebs.com/southernsmash
  #9 (permalink)
Old 05-17-2008, 06:08 PM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
Friend of mine had a tall block 427 in a Chevelle. There are no performance intake manifolds for them.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #10 (permalink)
Old 05-17-2008, 06:46 PM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
The 366 is very limited for performance as well, can't bore it, bore too small for bigger valves.....
As will all things, if the price is right and you're just going to drop and run with it, you can't go too wrong.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
