Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Expedition & Navigator 1997 - 2002 and 2003 - 2006 models
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 04:52 PM
NaviShock is starting off with a positive reputation.
Help! Have a leak somewhere....
I've noticed in my 2000 Navi that I have water trapped overhead that I can hear swishing around through the top of my cab. It first leaked from the inside molding above the drivers side window when it would rain. Now it seems to be coming out of the front grab handle on the drivers side. I know it's only a matter of time before it gets into the electrical system. I have no idea where it's getting in and how to get it out. Any ideas? Thanks.
  #2 (permalink)
Old 05-16-2008, 05:11 PM
NWBronco is starting off with a positive reputation.
Where do you here it swishing around? If in the front, take the front trim on the top of the windshield off. If further back, remove the overhead light. Either get a wet/dry shopvac and see if you can reach it, Or, get a lot of cloths and a coat hanger. If you remove the overhead light, disconnect the battery before you go through there.
  #3 (permalink)
Old 05-16-2008, 05:15 PM
alloro is starting off with a positive reputation.
Do you have a moonroof?
  #4 (permalink)
Old 05-16-2008, 06:00 PM
Quote:
It sounds like it goes from all the way front to all the way back as I move the truck forward and reverse. Will have to remove the light and see if that works.
  #5 (permalink)
Old 05-16-2008, 06:01 PM
Quote:
Yes I do. Thought about that but not sure how to tell that's where it's getting in.
  #6 (permalink)
Old 05-16-2008, 06:07 PM
pitrow is starting off with a positive reputation.
I've had exactly the same problem you're describing. It sounds like water is getting trapped in the sunroof pocket and then when you drive, it runs down the A-pillar. I've had the water dripping out of the grab handle, etc. Usually if you check your carpet in the footwells will be damp too. I asked around on here and the consensus on here was that it was blocked drains for the sunroof allowing water to build up and slosh around.
I never did find the cause of mine because I had no where dry to work on it during the rainy season and once the sun came out, I forgot all about it. It seems to have somehow fixed itself though, since I haven't had a problem with it in two years now and we've had one of the wettest winters on record this year. Sorry I know that doesn't help you much, but I'd at least check out your drains.
Oh one other thing, my initial thought was to just get some stiff wire and push it through the drains from the top to clear them out, but someone pointed out that they are plastic tubes and you could split them if you try that.
__________________
Mike
99 Eddie Bauer Expedition
5.4L, AWD, 3.73 LS Rear, Air Suspension
2000 Ranger
  #7 (permalink)
Old 05-16-2008, 06:24 PM
Doing some searching at the moment on other issues. Where exactly are these drains?
  #8 (permalink)
Old 05-16-2008, 06:32 PM
Compressed air works wonders for clearing those out. I did the ones that run down the front of each of the front doors. You'd be surprised at the crud that came out.
  #9 (permalink)
Old 05-19-2008, 11:54 AM
Quote:
I believe there's one in each of the four corners. The front ones run down the A-pillars and drain under the vehicle, and the back ones I think run down the B-pillars. I have no idea how you'd get to the rear ones though.
__________________
Mike
2000 Ranger
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
