Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane and Alternative Diesel Engine Fuels
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 03:16 PM
travisg96 is starting off with a positive reputation.
Red face Bio as solvent
I am working on cleaning up my head as I am waiting for gaskets to arrive so I decided to get some B99 to clean the parts up with figuring that it would be less toxic than using diesel or other chemical solvent. Started off this morning by wiping out my wash tub and filling it up with bio. Started out cleaning intake bolts that were encrusted with grime, so I put them in and walked away letting them soak. Came back about a hour later and started to brush them off with the parts brush. I noticed two things the grime pretty much just rinsed off and the silicon on the handle of the brush was starting to dissolve. As I progressed with my cleaning I would let the parts soak for a little while before scrubbing them down. It appeared as the bio got warmer it was cutting the grime with more ease. After finishing up I tried a bit scrubbing it on some encrusted grime in the engine compartment and it cut through it faster than anytime I had tried to pressure wash it. Well I don't know if I am he first person to notice this but I think tat I might start using bio as a cleaning solvent from now on. Besides cleaning faster and better my hands don't smell like I have been working in a car.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-16-2008, 03:26 PM
fabmandelux's Avatar
fabmandelux has a very good reputation on FTE.fabmandelux has a very good reputation on FTE.fabmandelux has a very good reputation on FTE.fabmandelux has a very good reputation on FTE.
I've been using B-100 in my solvent tank for years. Really works good, but it will remove paint if you leave it in to long!
I use it in my "normal" solvent tank, and also in my "automatic" parts washer. I have a 10 gallon can of "regular" solvent next to my parts washers to dip the parts in to remove the bio so the parts will dry faster, and not leave a "slimy" feel to them.
__________________
FABMANDELUX.
Don.
To join the Oregon Chapter, click HERE
  #3 (permalink)
Old 05-16-2008, 03:33 PM
Have you noticed it being more more solvent at higher temperatures? It is 80 deg outside right now so I would guess that it is the same temp being as it was sitting in the sun. Also it seems to dissolve the silicone on the end of the bolts and the where someone had tried to use as a make a gasket. I have never seen anything eat up silicone like that.
  #4 (permalink)
Old 05-16-2008, 04:18 PM
Yes, heat makes it work much faster. Watch for any plastic parts, because it will soften those too!
__________________
FABMANDELUX.
Don.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
