87 had a 460 95 has a 460, and had an Automatic. (Yes, I'm switching Auto to Manual, so LOTS of other things to move as well.) I just need to know if the 4sp manual will bolt up properly to the transfer case, and if the various linkages and mounts will fit the new truck.
it should all bolt up, except for the fact that the 87 had a cable speedo, and the 95 has an electronic speedo. so you will need a speedo blockoff plate if you use the 87 t-case. if you are going to use the 95 t-case, it should all bolt up.
i went the other way, i dumped the stick for an auto trans.
Thanks. In my case I'm converting the 95 to Electric. (Dual Warp 9" motors)
So I really need a manual transmission. (And the truck price was just too low to let the fact of it having an automatic bother me.)
I do plan on using the 95 Transfer case.
