Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 02:21 PM
OrangeJuice is starting off with a positive reputation.
Smile Leaky gas cap
Hi everyone,
This has been a problem since I bought my truck. The aft gas cap seems to spill a little fuel from the cap after filling up. The cap is a vented locking cap and I'm thinking the gas is leaking through the vented hole on the back side and not so much around the rubber seal. I'm having to clean the real quarter panel quite often. I try not to top off this tank as it seems to help a bit. Has anyone else experienced this problem with their caps and is there a fix to the problem.
Thank You
  #2 (permalink)
Old 05-16-2008, 02:25 PM
81-F-150-Explorer is gaining momentum as a positive member of FTE.81-F-150-Explorer is gaining momentum as a positive member of FTE.
Have you tried buying a new gas cap?
  #3 (permalink)
Old 05-16-2008, 03:32 PM
yes, I have replaced it several times with the same results.
  #4 (permalink)
Old 05-16-2008, 03:55 PM
Ds7776 is starting off with a positive reputation.
Ive had this problem on my 70 F100 with an in cab gass tank its the gas vapors expanding and pushing gas up into the fill hose. Ive had no success in fixing my leak but it seems to help when I park it so that the driver side sits up higher. O reven parking in the shade and not filling up right before parking.
__________________
i put it in the truck i thought god i hope i dont get pulled over, cop pulls me over and asks what that is, i said i dont know this aint even my truck.
1966 F100 352 longbed 2wd 4 speed
  #5 (permalink)
Old 05-16-2008, 04:32 PM
Quote:
Have you tried putting a non-locking cap on the truck. Locking caps are notorious for leaking through the seal.
Also if your truck is equipped with an evaporation system, check to see if the hoses going to the charcoal canister is in good shape, and also check the vent on top of the tank. Make sure there are no blockages.
Also, it is a good idea, especially with trucks with evaporative systems, not to top off the gas tank. Fill it to the first shutoff only to prevent gas from entering the evap system and blocking it. In California it is ilegal to top off a gas tank for this reason.
Good luck.
  #6 (permalink)
Old 05-16-2008, 05:07 PM
czaroc is starting off with a positive reputation.
Can you even fill a pre '77 in Calif? I have to drive around to find the "old" style pumps to fill mine. I can't get the new style nozzles to work.
  #7 (permalink)
Old 05-16-2008, 05:34 PM
Quote:
Yes but it's a pain in the you know where. The evaporation recovery on the gas station nozzle seals too well.
It's the same when you try and fill a gas can. Cant vent the air fast enough.
The best success I've had with my 1973, is to turn the gas nozzle upside down from normal. This keeps the nozzle from sealing 100% on the truck.
good luck.
  #8 (permalink)
Old 05-17-2008, 12:08 AM
Thanks for the help everyone. This leaking problem has never happened with the front gas cap, always the rear. Not sure why. Maybe the design/angle of the front filler tube?....I don't know. I've even seen the fuel spewing out of the rear cap area after filling-up and making a right turn...Yikes! I have not tried a nonlocking gas cap especially now with the high cost of fuel. I guess I could try it, but I'm worried someone would have a field-day with the amout of fuel our trucks hold.
Thanks again everyone.
  #9 (permalink)
Old 05-17-2008, 11:08 AM
Shamus's Avatar
Shamus is starting off with a positive reputation.
It truly sounds like that tanks vents are blocked.
__________________
1978 F150 Explorer 75th Anniversary Edition
  #10 (permalink)
Old 05-17-2008, 02:02 PM
They may be. I'll have to check that.
Thanks
  #11 (permalink)
Old 05-17-2008, 03:52 PM
It spews out when you turn could you tank supports straps or brackets be broke or hang lower on one side?
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
