spider gear thrust washers
Is there a trick to getting the thrust washers in behind the spider gears. It's on a 10.25 rear. I was starting install a lock right and as I took things apart I saw that I had a limited slip carrier which won't work with this locker. I'm putting everything back until I find an open carrier. When I roll the spider gears in place it spits out the thrust washer. Any ideas?
i had the same problem when i rebuilt the LS in my 8.8 b/c i added a exta friction disc on each side so it was extra tight so it locked up more......
grease is your freind.....but like i said, i had to put the washer in a little further so when you turn the gears in when the washer stops, the spider gear will keep turning and the washer will fall in its place and go in..........
but i can see that somehow pressing the side spider gears apart would help some.....
east302
06-15-2016 07:52 PM
cabloom300
03-22-2016 08:12 AM
Zazoos
02-11-2015 11:12 PM
