Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 01:30 PM
ozx3+1's Avatar
Makes my head spin
ozx3+1 is gaining momentum as a positive member of FTE.ozx3+1 is gaining momentum as a positive member of FTE.
Enhanced PID listing?
Does anyone have a list or a link to of all the PIDs for our 6.0's? I'm getting more curious, and want to use my ScanGauge II for more than it's doing now.
Thanks,
Brian
aka
__________________
Brian
  #2 (permalink)
Old 05-16-2008, 05:54 PM
ozx3+1's Avatar
Makes my head spin
Bumped 'cuz I want this to be seen again by the East coast folks just getting home about now...
  #3 (permalink)
Old 05-17-2008, 07:33 PM
ozx3+1's Avatar
Makes my head spin
Bump... One of the techs must have this info. Please chime in...
__________________
Brian
  #4 (permalink)
Old 05-18-2008, 11:19 AM
ozx3+1's Avatar
Makes my head spin
Wow! Sucks to be me...
  #5 (permalink)
Old 05-18-2008, 11:48 AM
BPofMD's Avatar
BPofMD has a very good reputation on FTE.BPofMD has a very good reputation on FTE.BPofMD has a very good reputation on FTE.
Take your time...it's Sunday and these poor overworked Diesel techs are taking some well deserved time off to be with their family!!! It's free...ya gotta wait for it!!
__________________
BPofMD
Maryland Asst. Chapter Leader
& PlankOwner
Bud
2005 F250 PSD 4X4 LB Arizona Beige
Join the Maryland Chapter click HERE
FORD ALL TRUCK NATIONALS
AUGUST 8--10, 2008 INFO HERE!
  #6 (permalink)
Old 05-18-2008, 06:55 PM
ozx3+1's Avatar
Makes my head spin
Quote:
Happy to wait. Just keep bumping it to the top so it don't get lost
__________________
Brian
  #7 (permalink)
Old 05-18-2008, 07:23 PM
wb6anp is starting off with a positive reputation.
try this site.
http://www.competitiondiesel.com/for...d.php?p=269521
__________________
2006 F-250 Harley Davidson Dark Torreodore Red /black flames
Accufab Elbow
Silverline 4" Cat Back exhaust
Dieselsite coolant filter
DiPricol Optix gauges
http://community.webshots.com/user/wb6anp
  #8 (permalink)
Old 05-18-2008, 09:22 PM
bismic's Avatar
bismic has a good reputation on FTE.bismic has a good reputation on FTE.bismic has a good reputation on FTE.
Quote:
Originally Posted by wb6anp View Post
Thanks WB6anp!! Looks like a great site.
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; CCV filter
Fumoto; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco; DashDaq & britebox on deck
Line-X, CPOhighway Prod. tool box, tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
  #9 (permalink)
Old 05-19-2008, 07:09 AM
ozx3+1's Avatar
Makes my head spin
Thanks for the link, but I'm looking for PID's (Process IDentifier's). The link is to a great site for DTC's (Diagnostic Trouble Codes). I'll read it completely once I'm awake to insure I didn't miss something. Now, off to get coffee...
__________________
Brian
  #10 (permalink)
Old 05-19-2008, 02:31 PM
Beerstalker's Avatar
Beerstalker has a good reputation on FTE.Beerstalker has a good reputation on FTE.Beerstalker has a good reputation on FTE.
You could check out the pdf I posted here.
http://www.ford-trucks.com/forums/58...ml#post5214583
That contains all the parameters my Dashhawk can read as well as my normal readings. This was with an older version of the firmware, and I haven't messed with it in a while to see if there has been much more added yet. Not sure what all you can get with the Scangauge, but these are definitely available from the OBD-II port.
__________________
2007 F350 Lariat, CC, LB, 4x4
4.5" DR Lift w/35x12.5r20 Toyo Open Country M/Ts
Keystone Restyling Ram Air Hood W/Airaid Intake & Pre-filter
Recon Smoked Cab, Mirror, and Brake Lights
MSD Dashhawk w/A Pillar Mount
Dieselsite Coolant Filter
Lund Eclipse Window Vents
Weatherguard Toolbox
  #11 (permalink)
Old 05-19-2008, 02:51 PM
ozx3+1's Avatar
Makes my head spin
Thanks, Beerstalker. I apreciate the info, however what I'm challenged with is defined in the attached PDF. Here's a breif synopsys of the rocket science...
CAN TXD
The first 4 characters in CAN are the identifier. The following characters are the data to send. The ScanGaugeII looks for a response ID which has the high bit of the third character flipped from that of the transmit ID. The lower 3 bits of the third character are "don't care" bits for the receive. Further selection of the response in the RXF is used to screen the responses.
Example: A CAN mode $22 PID $4923 State-of-Charge for the Escape Hybrid would be:
0745224923
The 0745 is the ID to send for this request. The response must have an ID in the range of 0748 to 074F. In the case of the Escape Hybrid, the response ID would be $074D which would be accepted.
With this as a baseline, I guess I'm looking for the CAN mode $22 PID's for the super Duty's. Once I have them, I can program the ScanGauge II to tell me many things...
__________________
Brian
  #12 (permalink)
Old 05-19-2008, 06:26 PM
Wow, yeah I can't help you with that stuff, it's a bit over my head. I just thought you were looking for what parameters the Ford system keeps track of so you could ask Scangauge to look into them. Didn't realize you were trying to write your own programming for it.
All I can say to that is good luck.
And if you find out a way to get fuel pressure be sure to let me know, as I've been trying to get MSD to add it the the Dashhawk, but they can't figure it out.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
