Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 01:26 PM
maverick1701 is starting off with a positive reputation.
I broke my truck today, need some help finding the problem
So I was driving to work and about 20yds outside of my apartment my engine began to drive really rough (but went back to normal when I let off the clutch) then I lost all hp and was slowed to a crawl. I decided to turn around and come back home when it died on me after throwing out a big white (possibly blue, I only caught the tail-end of the smoke cloud in my mir.) cloud of smoke. Any ideas?
I looked under the hood and this cap was blown off and the fluid level is very high....about 1in from the cap. It also shot the liquid all over the side of my engine when it blew.....do yall have any ideas?
I sure hope yall can help me out.. I need my truck for work/school
-Chris
__________________
1996 F-350 Crew-Cab LWB w/7.3;201K miles;33in toyos;6in lift;E4OD;Warn Hubs;Replacement bumpers
1994.5 F-350 Crew Cab LWB W/7.3 Powerstroke;317,000 miles;410s;33in BFG Mud-Terrain 305/70-R16;5-spd;Warn hubs;115gal transfer tank;grill guard;no cats;no muffler;Trail-Boss "Roper Rack"
http://youtube.com/watch?v=BRzhJdmGYNY
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-16-2008, 01:32 PM
Neal 97 250's Avatar
Neal 97 250 is gaining momentum as a positive member of FTE.Neal 97 250 is gaining momentum as a positive member of FTE.
That is the power steering fluid reservoir. That shouldn't do any of the symptoms you described. Except for maybe the smoke on the exhaust manifold.
Do you have the factory Flywheel in the truck?
My guess is that the DMF went bad and the vibration caused the cap to come off a bit and dump fluid on the exhaust manifold. Have you tried to crank it again? Does it vibrate in neutral with the clutch out or clutch in?
It probably felt like it lost power because of the vibration. More info needed.
__________________
97 F250 7.3PSD
X-Cab, SWB, 4X4
5spd, 4.10gears
3.5” DP, 4” Exh.
AFE Intake
FPR,BDP 140v IDM,CCV,HPX
Rosewood Stage II's
6 pos. TW chip, wow !!
'00 Excursion 7.3PSD 4X4
6637 intake
drill/slot rotors
Neal's Pics
  #3 (permalink)
Old 05-16-2008, 01:55 PM
Action4478 is gaining momentum as a positive member of FTE.Action4478 is gaining momentum as a positive member of FTE.
-Chris
The steeringfluid is from steering it without the motor running ...The stalling is another matter...Need to do some testing ,, Oil level , fuel level in the filter ,Check the wiring to the valve covers for loose or burned connections ,,,If you are running a chip ,, unplug it (make sure the key is off )....
__________________
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
www.fordtransmissioncure.com
Special thanks to RacerX www.racerxautomotive.com
  #4 (permalink)
Old 05-16-2008, 02:04 PM
Cuda_jim's Avatar
BECOME A ------------>
Cuda_jim has a good reputation on FTE.Cuda_jim has a good reputation on FTE.Cuda_jim has a good reputation on FTE.
Yep, Rick (Action4478) nailed the power steering thing. When you turn the steering wheel with the engine off it will pukes fluid out of the top.
The engine stalling is another issue. Does the tach move when you are cranking it?
If not, my guess is CPS...but you need to answer Ricks questions above.
  #5 (permalink)
Old 05-16-2008, 02:05 PM
tjbeggs's Avatar
Fisher of Men
tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.
Yep what Rick said!
__________________
Tim
Proud User of "The Cure"
For sale- 95 accelerator pedal, Gray interior and dash part, cab and more PM your request!
Click the Picture for wiring diagrams, tech info and Pictures!
  #6 (permalink)
Old 05-16-2008, 02:14 PM
Were you driving it hard? Don't forget to check the HPO reservoir level.
Was it very cold outside when it did this?
__________________
97 F250 7.3PSD
X-Cab, SWB, 4X4
5spd, 4.10gears
3.5” DP, 4” Exh.
AFE Intake
Rosewood Stage II's
6637 intake
drill/slot rotors
Neal's Pics
  #7 (permalink)
Old 05-16-2008, 05:14 PM
Alrighty I am about to go out and run through and check out all of the things yall mentioned.
But I can answer some Q's now
It was not cold outside when it happend, I think it is maybe 86ish here in east tx.
I was not driving it hard, I had started the truck maybe 3 mins before it happened. I let it idle for about 2mins before leaving my apartment was going up a hill in 1st gear w/med to low rpms becuase the engine was warming up still and it went out.
What is the HPO reservoir?
About the flywheel I have no idea if it is the factory flywheel, when I bought the truck the last owner didnt say either way but I can email him and check.
On edit: I am not using a chip or anything
__________________
  #8 (permalink)
Old 05-16-2008, 05:38 PM
Good news yall...
I went out and checked if the tach moved while cranking. While cranking the tach moved, so just for giggles I kept cranking and it had a little trouble starting but it eventually started and ran fine (and starts fine now). It was starting like it used to before I changed out my battery cables (both + and -). This is pretty strange yall....
Does it sound like I have some wiring issues? Maybe something not grounded correctly?
__________________
  #9 (permalink)
Old 05-16-2008, 06:55 PM
Todd525's Avatar
Todd525 is starting off with a positive reputation.
batt connections tight? Check your oil level. Is it correct?
__________________
96 F350 CC Dually PSD. Tuner, straight pipe, 6637 filter, ribbed diff cover, 12.7k mod, 28k tranny cooler, 3 plate TC, autometer boost, trans, and pyro. Used 4 Car Haulers, 5th wheels, goosenecks, Fat Chicks.
01 F250 CC 4x4 PSD. SOLD.....Kinda missed already, and its Day 1.
  #10 (permalink)
Old 05-16-2008, 09:56 PM
61 uni is starting off with a positive reputation.
His truck has over 300k. If it still has the dmf, it is the best one they ever made.
__________________
96 f250 PSD
4:10 gears
5 speed
LuK clutch
Bought Feb. 07
Replaced so far:
1.vacume pump
2.fan belt
3.brakes(front and rear)
4.flywheel and clutch kit
5.gpr
6.altenator
  #11 (permalink)
Old 05-16-2008, 10:15 PM
What is a "DMF"?
__________________
  #12 (permalink)
Old 05-16-2008, 11:18 PM
95psd is starting off with a positive reputation.
Dual mass flywheel
  #13 (permalink)
Old 05-17-2008, 04:41 PM
So the problem is still there...
I drove it all yesterday (After it died) and it ran very well, plenty of power, great idle etc
Well it started running rough again today, I limped it off the road and shut off the engine for a few mins. When I restarted it ran fine.
Could I have gotten my hands on some bad fuel? I bought the fuel about 2 weeks ago, it has been in my transfer tank with some diesel kleen to help stabilize the fuel.
__________________
  #14 (permalink)
Old 05-17-2008, 06:52 PM
Todd525's Avatar
Now the way that you descibe it it almost sounds like a CPS or VCWH. I would bet more on the cps though. Very similar conditions. YOu have a code reader? Access to a buddy that has a edge tuner to pull codes?
__________________
  #15 (permalink)
Old 05-17-2008, 07:39 PM
Robbgt's Avatar
Robbgt is gaining momentum as a positive member of FTE.
Try what everyone else says first... then if everything else fails find a buddy's PSD and swap out the IDM. My truck had the exact same symptoms when the IDM was dying. the chances of that happening are very slim, and it is an expensive part to replace. Usually there good or dead, no intermediate. I lucked out I guess.
-Robb
__________________
97 F-350 XLT 4x4 PSD, E40D, 3.55's, 153K, 6637, 140V IDM, HPX, FPR Shim, Hotfoot, Tymar DP, Dual Exhaust, T/C Lockup mod, new GP's, Stancor GPR.
>>FOR SALE: FTE Classifieds<<
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
