Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1997 - 2003 F150 97-03 F-150, 97-99 F250LD, 7700 & 04 F-150 Heritage
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 11:17 AM
JUSTINRVS is starting off with a positive reputation.
97 F-150 Won't start, Anti Theft??? Please Help
So I was home unloading my truck with the raido on for about half an hour or so...Go to start and move my truck...yeah, turn the key, all the dash lights come on just like normal, but no dim when I try to start it...nothing, I can go pop the starter and its all good runs and drives, but the key will not start it...
Everything has been working normal and very well, I've only had the truck for a week so I'm still not very in tune with it yet. I bought the truck with only a standard steel key, no key fob, but if I do lock the doors with the switch the "theft" light turns on, so it leads me to believe that it has a stock alarm in it.
Please if you can help that would be great!!!
  #2 (permalink)
Old 05-16-2008, 11:28 AM
rebelyell618's Avatar
rebelyell618 is starting off with a positive reputation.
this will sound stupid but:
if it is an automatic just push the gear selector up towards park (just an upward push).
my superduty does this and when i hit the selector up it will act normal and start right up.
__________________
2000 Ford F-250 Crewcab 4X4 5.4
stock height (for NOW), T3 grille guard, many minor mods with more be putting on everyday.
  #3 (permalink)
Old 05-16-2008, 11:37 AM
here is a thread of what i was talking about.. just throwing ideas
http://www.ford-trucks.com/forums/736039-need-help.html
__________________
  #4 (permalink)
Old 05-16-2008, 11:44 AM
Thanks for the thought...I tryed that last night before I gave up and had it towed lol
I'm getting solinoid click under the dash and thats it...
  #5 (permalink)
Old 05-16-2008, 01:12 PM
KingRanchMan02's Avatar
KY KR lover
KingRanchMan02 is gaining momentum as a positive member of FTE.
When you try to start it does the theft light blink off and on?
What is the voltage on the battery when measured from battery post to post? Should be around 13.2 VDC. If the voltage is low, under 12 VDC and it has been on a battery charger, then replace the battery.
If battery voltage is good, then check voltage from the negative post to positive cable clamp. Voltage should not change. If it does, remove cable, clean post and clamp, reassemble and retest. Repeat this test in the reverse too. (Positive post to negative clamp).
Now, if the battery is good and you still have a starting problem. The battery is connected directly to the starter by a heavy battery cable (it is also connected to the starter relay). Test the voltage at the starter to a good vehicle ground. If the voltage is low, then clean up the connections, check the cable for corrosion wicked up under the insulation. Correct any problems found here.
On the other hand if the voltage is good here, then check the smaller wire at the starter for voltage when the ignition switch is in the start position. If there is no voltage there when the switch is on, then go to the starter relay.
The starter relay has three wires. One is from the battery(red), one to the starter(red), and the other(tan/red) is from a fuse (hot in start, F21) in the central junction box via the digital transmission range sensor. If you have no voltage out to the starter then check to insure that the tan/red wire is hot in start. If not, then troubleshoot back to the fuse and the DTR sensor. If this is good and there is no voltage on the red wire to the starter, then replace the starter relay.
Good luck!
__________________
John
aka KingRanchMan02
`02 F-150 King Ranch SuperCab
Charcoal Blue/Arizona Biege
5.4L 3.55 LS, 4x2
Diablosport Predator Programmer, K&N filter.
  #6 (permalink)
Old 05-16-2008, 01:33 PM
Starting Problem Fixed
Ok Here You All Go.................
Slot 21 On Interior Fuse Box, Starter Relay Fuse, I Have Owned My Truck For Almost 2 Weeks And I Have Not Moved Or Replaced Any Fuses....
Slot 21 Is The Starter Relay Fuse, Replaced And Runs Great!!!
  #7 (permalink)
Old 05-16-2008, 05:46 PM
Trusty Rusty is starting off with a positive reputation.
My wife's jeep had a problem like this. We were able to disconnect the battery, let it reset for a minute, reconnect and hit the road. I always felt that computers were like best friends.... sometimes they just need to be slapped. Bit obviously the fuse was the problem for you. Just thought it might help someone else.
__________________
Lead, Follow, or Get the Heck out of my Way.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
