Axle shaft seal replacement?
i need to know how to change the axle shaft seal on my d44 front. this seal is the one that is attached to the outer axle shaft. not the ones in the diff. the package consists of 2 plastic rings, a rubber seal an a metal ring. i cant figure out how to remove and replace the metal ring. i thinks its called a slinger. this is the last thing holding me up so i need to know how to do this asap!
Thanks Bob
__________________
Untill next time, I leave you with these words of wisdom...
