Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 10:33 AM
466Cyclone's Avatar
466Cyclone is starting off with a positive reputation.
94 F150 4x4 steering issues
Greetings Ford Truck folks. I have a 94 F150 4x4 with stock size tires, power steering/brakes and about 140k on it. It has some steering troubles. I realize it's difficult to do armchair diagnostics, but I could use some direction.
The truck steers quite hard, and doesn't want to come back to center after turning either direction. It wants to stay the direction you last aimed it. When you bring the wheel back to center, it's just difficult to say the least as you navigate these meandering new england roads.
I know it needs u-joints in the front wheels, and the tie-rods/ball joints are somewhat loose, but I doubt either of those would cause this. The power steering fluid is where it should be, and the PS pump is whining like a bit*h as you fight the wheel. I have owned Fords all of my life and realize they have noisy pumps, and again, I doubt it's the pump. I'm stumped. Steering box? PS setup?
Any ideas?
-Brian
94 F150 4x4 302 5-speed
70 Mercury Cyclone 466 4-speed 3:50
65 Mercury Comet 302 4-speed 4:11
  #2 (permalink)
Old 05-16-2008, 01:11 PM
alz alz is offline
alz is starting off with a positive reputation.
Yes, the front axle u-joints can cause this. They need to be able to pivot when you turn the wheels.
Bad ball joints and loose tie rod ends can cause this as well.
My first guess would be the u-joints though.
__________________
1995 F150 4x4 SC 302 4R70W MAF
  #3 (permalink)
Old 05-16-2008, 01:34 PM
466Cyclone's Avatar
Thank you
I appreciate the feedback. Since I know I need to do the u-joints I'll start there, hopefully this will clear things up. Although, doing the u-joints is a big job I am told. Don't the axles need to be pulled and the ball joints/spindles dropped out?
-Brian
  #4 (permalink)
Old 05-16-2008, 02:10 PM
alz alz is offline
Spindles need to be removed.
Do you have auto or manual hubs?
With manual hubs, raise the front end, turn the steering wheel all the way left or right. Lock your hub and spin the wheel. You will be able to tell if the joint is bad, it will bind. Check both sides.
With auto hubs, raise the front end, remove tie rod ends and try to turn the wheel left to right by hand. Again, if it binds it's bad.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
