i want to get new exhausts to put on my truck. I already have Flowmaster (dont know what type) on there it sounds ok, but i wanna make it as loud as possible. I want to stay with Flowmaster. Can y'all give me some feedback on what i should get?
Flowmaster 10 series muffler, it is a single chamber muffler.
there are other makers the exact same muffler for cheaper price such as a cherrybomb extreme about 20-40 bucks cheapers. just saying even though you wanted only flowmaster.
__________________ 2000 Ford F-250 Crewcab 4X4 5.4
stock height (for NOW), T3 grille guard, many minor mods with more be putting on everyday.
You want it as loud as possible? Straight pipe should do that........
The "sounds cool" factor will probably get old real quick with the setup you're thinking of.
I have a Borla muffler with a side exit (Lighting style) and it almost sounds stock at idle and under smooth acceleration, but it really sounds nice and deep when I stomp on the gas (not very often, with gas prices lately).
i dont want to have exhausts coming out the back i wanna stay with turn-downs. can i do that with turn-downs?
One problem with turn-downs is the soundwaves will bounce off the ground and back to the floor of the truck, which may cause some annoying vibrations. But since you're after loud exhaust, shouldn't really matter in your case. Also, turndowns can cause mositure build up under the truck, may or may not be a concern depending where you live and rust problems. Also, the longer the pipe, usually the louder the exhaust will sound. Shorter pipes usually give you that raspy, crackle to the exhaust sound.
