Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1997 - 2003 F150 97-03 F-150, 97-99 F250LD, 7700 & 04 F-150 Heritage
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 09:49 AM
Joel_P_Jr's Avatar
Joel_P_Jr is starting off with a positive reputation.
i am lookin for new exhausts
i want to get new exhausts to put on my truck. I already have Flowmaster (dont know what type) on there it sounds ok, but i wanna make it as loud as possible. I want to stay with Flowmaster. Can y'all give me some feedback on what i should get?
  #2 (permalink)
Old 05-16-2008, 11:35 AM
rebelyell618's Avatar
rebelyell618 is starting off with a positive reputation.
Flowmaster 10 series muffler, it is a single chamber muffler.
there are other makers the exact same muffler for cheaper price such as a cherrybomb extreme about 20-40 bucks cheapers. just saying even though you wanted only flowmaster.
__________________
2000 Ford F-250 Crewcab 4X4 5.4
stock height (for NOW), T3 grille guard, many minor mods with more be putting on everyday.
  #3 (permalink)
Old 05-17-2008, 05:56 PM
triton_2002's Avatar
triton_2002 is starting off with a positive reputation.
You want it as loud as possible? Straight pipe should do that........
The "sounds cool" factor will probably get old real quick with the setup you're thinking of.
I have a Borla muffler with a side exit (Lighting style) and it almost sounds stock at idle and under smooth acceleration, but it really sounds nice and deep when I stomp on the gas (not very often, with gas prices lately).
__________________
2002 F-150 Supercab 5.4 Triton V8
Arizona Biege
  #4 (permalink)
Old 05-17-2008, 06:01 PM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
Yep, just leave the cats and remove the muffler and install a piece of pipe.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #5 (permalink)
Old 05-19-2008, 05:27 PM
97Handshaker's Avatar
97Handshaker is starting off with a positive reputation.
i have true duals with no mufflers and it is pretty loud.
the only thing louder is to take off the cats
  #6 (permalink)
Old 05-19-2008, 05:42 PM
DoubleFbomb is starting off with a positive reputation.
true duals are where its at. =)
  #7 (permalink)
Old 05-19-2008, 06:07 PM
Joel_P_Jr's Avatar
i dont want to have exhausts coming out the back i wanna stay with turn-downs. can i do that with turn-downs?
  #8 (permalink)
Old 05-19-2008, 06:09 PM
i dont see why not
  #9 (permalink)
Old 05-19-2008, 06:21 PM
Quote:
One problem with turn-downs is the soundwaves will bounce off the ground and back to the floor of the truck, which may cause some annoying vibrations. But since you're after loud exhaust, shouldn't really matter in your case. Also, turndowns can cause mositure build up under the truck, may or may not be a concern depending where you live and rust problems. Also, the longer the pipe, usually the louder the exhaust will sound. Shorter pipes usually give you that raspy, crackle to the exhaust sound.
__________________
Arizona Biege
  #10 (permalink)
Old 05-19-2008, 08:10 PM
Joel_P_Jr's Avatar
another reason is that it is easier to install and you cant see the rust on turn-downs
  #11 (permalink)
Old 05-19-2008, 08:28 PM
you may not see the rust, but it's still there.....go with stainless if you can afford it.
__________________
Arizona Biege
  #12 (permalink)
Old 05-19-2008, 08:47 PM
Dustin1690 is gaining momentum as a positive member of FTE.Dustin1690 is gaining momentum as a positive member of FTE.
If you want loud straight pipes is the way to go loudest you will get with flowmaster are 40s or those 10s
__________________
Dustin - Southern Saskatchewan Canada
My Truck:
1993 F150 XLT Reg cab Long box 351 (5.8L) E4OD 2wd 3.55 non limited slip axle factory ten hole aluminum rims
Dad's Truck:
1992 F150 XLT Supercab Short box 302 (5.0l) E4OD 2wd 3.55 non limited slip axle factory five star wheels
  #13 (permalink)
Old 05-19-2008, 08:52 PM
Joel_P_Jr's Avatar
thats another problem: i dont know where to look for them and i most likely wont have the money 4 them.
  #14 (permalink)
Old 05-19-2008, 09:22 PM
Local muffler shop should give you an estimate
__________________
Arizona Biege
  #15 (permalink)
Old 05-19-2008, 09:35 PM
Joel_P_Jr's Avatar
ok thnx
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
