Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Expedition & Navigator 1997 - 2002 and 2003 - 2006 models
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 09:23 AM
shov76's Avatar
shov76 is starting off with a positive reputation.
2003 Expy Rear Brakes
I know I saw it somewhere but can't find in the search. Last year I used a step by step post to change the front brakes and rotors. It was very detailed right down to the tools needed. Worked like a charm and had NO problem getting both rotors off. Looking for the same for the rear. The only difference (I think) is the addition of the emergency brake. I've already bought the pads and rotors and plan on doing it tomorrow.
I'll try without directions because it dosen't seem to difficult but would apprecieate feedback or link to someting that might prepare me.
Thanks,
Shov
__________________
Shov
2003 E.B. Expy
5.4 HD Tow Package
2008 Springdale 296 Travel Trailer
1976 Shovelhead
  #2 (permalink)
Old 05-16-2008, 09:40 AM
tatetodd is starting off with a positive reputation.
Rear pad remove replace will seem very familiar as they are basically same as fronts with same tools just smaller calipers.. haven't changed my rotors yet but would guess they'd be pretty much the same as well.
  #3 (permalink)
Old 05-16-2008, 11:58 AM
shov76's Avatar
Thats what I thought.
__________________
Shov
2003 E.B. Expy
5.4 HD Tow Package
1976 Shovelhead
  #4 (permalink)
Old 05-16-2008, 12:48 PM
Frat-man-du is starting off with a positive reputation.
I have not had to to my 03 Exp yet but on my 98 Lincoln and 00 stang I have to use a special tool to rotate the caliper piston back. You can 't push them back like on the fronts. I have a tool that has two pins that fit into the holes on the piston and you just rotate it clockwise till it is flush with the base (oh - make sure the master cylinder cap is off first and watch the fluid so it does not overflow).
  #5 (permalink)
Old 05-17-2008, 03:07 PM
shov76's Avatar
Feedback on the brakes....
Real easy. Just bang um off. E - brakes shoes looked good. Just comprees the caliper before removing. I checked fluid level in master cylinder and used a screwdriver against the rotor .You"ll need a 6mm hex, large screwdriver (to stick between caliper and rotor to compress) and a 18mm wrench to do the job. Don't forget the big hammer!
Took about an hour after I got the right tools.
__________________
Shov
2003 E.B. Expy
5.4 HD Tow Package
1976 Shovelhead
  #6 (permalink)
Old 05-17-2008, 08:34 PM
alloro is starting off with a positive reputation.
Quote:
Originally Posted by Frat-man-du View Post
I have to use a special tool to rotate the caliper piston back. You can 't push them back like on the fronts. I have a tool that has two pins that fit into the holes on the piston and you just rotate it clockwise till it is flush with the base.
Expeditions have a separate parking brake assemble and do not use the rear calipers for the parking brake. Because of that, it is not necessary to screw them in, you just compress them as you would the fronts.
  #7 (permalink)
Old 05-18-2008, 12:02 AM
AtlPikMan is starting off with a positive reputation.
Ive Checked my pads they all look good. Why do i still get this Squealing when driving slow?
  #8 (permalink)
Old 05-18-2008, 09:08 AM
Maybe you have a dragging parking brake shoe. Have you inspected them?
  #9 (permalink)
Old 05-18-2008, 11:47 AM
sbclemens is starting off with a positive reputation.
How do the rotors look? Have you changed the brake fluid recently? Do you see and fluid leakage anywhere? Try using a caliper lube.
__________________
98 Expy XLT 4x4 5.4L
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
