Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1997 - 2003 F150 97-03 F-150, 97-99 F250LD, 7700 & 04 F-150 Heritage
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 09:07 AM
mel2000f150 is starting off with a positive reputation.
E-brake broken
Yesterday my e brake padel did not fill right when I engaged it.
What I found is the cable on the right rear came off the acuator & the acuator is sticking out like it has been pulled back(engaged). How do I get the rotor off. Is it just stuck? I used WD40 & a hammer (and a block of wood)to no luck, is PB blaster better or should i use some heat from a torch.
__________________
2000 F-150 scab 4x4 offroad
2003 Mazda 6s
2005 Rockwood 5er
  #2 (permalink)
Old 05-23-2008, 09:12 PM
ajm859830 is starting off with a positive reputation.
Mine did the same thing. If youre talking about that little metal tab that sticks out that the cable connects to as the actuator then you need to tap it back into the non enganged position and the rotor will then come off. I used some pb and a deadblow hammer.
  #3 (permalink)
Old 05-23-2008, 09:25 PM
triton_2002's Avatar
triton_2002 is starting off with a positive reputation.
My e-brake was working fine and it still took a while to knock off the rotors with a 3lb sledge and a block of wood
__________________
2002 F-150 Supercab 5.4 Triton V8
Arizona Biege
  #4 (permalink)
Old 05-23-2008, 10:30 PM
mjunk1 is starting off with a positive reputation.
My actuator lever was gone and when I pulled the rotor off there was nothing inside! I can't understand why someone would just take everything out and not fix it. Not that an e-brake is the most useful thing, until you really need it, but why they would just tear it all out and leave it is beyond me. Strange that so many have this problem with the cable coming off.
__________________
2001 F150 Screw 4X4
1966 F100 currently being rat-rodded
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
