Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1997 - 2003 F150 97-03 F-150, 97-99 F250LD, 7700 & 04 F-150 Heritage
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 09:05 AM
grayfox350 is starting off with a positive reputation.
2003 f150 ball joint questions
I used 4 wheel drive on saturday ... while driveing down the highway on monday i got a shimmy in the streering wheel and now it comes and goes and help or suggestions with this problem....
Also I can't find the grease nipple on the ball joints to grease up my gears please help with that too
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-16-2008, 06:14 PM
randy6800 is starting off with a positive reputation.
the factory ball joints are sealed and do not have grease fittings. Did you go into the mud four wheeling?, In the past ive had mud get into the wheels and it causes a out of balance problem.
  #3 (permalink)
Old 05-16-2008, 06:33 PM
galaxie641 is starting off with a positive reputation.
I agree sounds like mud/ice in the rim. Aside from not being able to grease the ball joints DO NOT put any kind of needle in there and try to grease them. You will absolutely destroy them if you do that. Same goes for any other sealed joint.
You may have also thrown a wheel weight the more I think about it. I'd clean the rims and have them rebalanced and go from there.
__________________
'48 F1 Flat6
'51 F3 Flat8
'64 Galaxie 352 4bbl
'68 F150 390
'72 F250 400/C6
'97 F150 5.4L
  #4 (permalink)
Old 05-16-2008, 09:23 PM
Bobby82490 is starting off with a positive reputation.
[quote=galaxie641;6162080]I agree sounds like mud/ice in the rim. Aside from not being able to grease the ball joints DO NOT put any kind of needle in there and try to grease them. You will absolutely destroy them if you do that. Same goes for any other sealed joint.[quote]
Im just curious.. why would it destroy it? I have greased some of my sealed steering/suspension components with a grease needle, and they are doing fine.
__________________
-1998 F-150 5.4l auto 2wd, with a worn out 3.55 LS
-219,000+ miles w/ all orig. drivetrain
-No Muffler
  #5 (permalink)
Old 05-17-2008, 08:51 AM
Grease eats the plastic/rubber that is inside them. Motorweek had an excellent section on it a few months ago that showed a sealed Tie rod and a greaseable tie rod. They cut them in half and showed what happens when you grease a sealed unit. Aside from the grease eating them you puncture them and allow contaminants in.
__________________
'48 F1 Flat6
'51 F3 Flat8
'68 F150 390
'72 F250 400/C6
'97 F150 5.4L
  #6 (permalink)
Old 05-18-2008, 07:25 AM
So do the sealed ones not have grease in them?
__________________
-No Muffler
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
